Old 03-06-2009, 02:51 PM
ROBERT DAVIS ROBERT DAVIS is offline
Default "Poll" on Compressions 74/80-71/80-78/80/-76/80
Hi,
I am looking at purchasing a plane with 455 TTSN Aerosport 0-360 Engine & Hartzel prop.
Should I be worried about the compressions?
1 2 3 4
74/80 71/80 78/80 76/80
Would like to hear from you all.
Thank you
Old 03-06-2009, 03:03 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Check that they were measured...
...with a 0.040 orifice as per Lycoming's SBs.
If it was done with a 0.060 orifice, then the compression is really poor.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-06-2009, 03:05 PM
Mel's Avatar
Mel Mel is offline
Default I see no problems with those readings at all.
Number one, differential compression is a relative measurement. You can go fly that airplane for an hour and get totally different readings. You should be concerned when the compression is greater than 20% between the high and the low reading, or if any reading is lower than 60/80.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-06-2009, 03:22 PM
Geico266's Avatar
Geico266 Geico266 is offline
Good to go.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 03-06-2009, 05:34 PM
gasman gasman is offline
Originally Posted by ROBERT DAVIS View Post
Hi,
1 2 3 4
Thank you
To understand the condition of the motor, have your mechanic do a COMPRESSION TEST. The way it is done in the automotive world. It will show you more than just that the cylinder will hold air.
Old 03-06-2009, 06:16 PM
az_gila's Avatar
Smile Ahh... but...
Mr. Lycoming says (salient points only - see SI 1191 for full details)....
* Should be nearly equal - 5 psi difference is satisfactory - 10 to 15 psi difference should be investigated.
* Over 15 psi - check again within next 10 hrs.
* All above 70 psi - engine is satisfactory
* less than 65 psi indicates wear and should be tracked with 100 hr measurements
* below 60 psi, or a rapid increase in wear rate, cylinder removal should be considered...
Based on this (the manufacturer's data) - your engine sounds fine...
Gil Alexander
Old 03-08-2009, 12:32 PM
buck buck is offline
Default Poll on compression
Remove the oil cap, open the throttle and apply the air to the cyl., listen at the exhaust, oil inlet, and air screen. This will tell you what is leaking, exhaust valve, rings, or intake valve.
Walt RV-6A
IO-320 CS finishing up
Old 03-08-2009, 01:25 PM
breister breister is offline
I may be whistling in the dark, but I THINK that engine compression rating affects the expected outcome.
All answers so far are correct for 8.5:1 "standard" compression. I'm not sure how this varies for a "low compression" or "high compression" engine.
Old 03-09-2009, 06:19 AM
MarinePilot MarinePilot is offline
Default Compression
Was the compression performed cold or hot? What was it the previous year??
Old 03-09-2009, 09:07 AM
rgbewley rgbewley is offline
Compression checks are subjective because you can move the piston 32nd of an inch and get a drastically different compression reading. Compression checks alone are in no way suitable for diagnosing the health of the engine.
We consider mid-time engines that come through our shop that have compression of 60 or less through the rings as marginal and pull them to inspect and re-ring, with possible honing work if needed. Any leak past the valve is unacceptable and requires immediate repair. I believe Lycoming says that 50/80 meets continued airworthiness standards.
Hope this information is helpful to you.
Rhonda Barrett-Bewley
