Old 03-06-2009, 01:47 PM
jimbo jimbo is offline
Default Dimpling J stringer
When I go to dimple the wing J-stringers there's not enough clearance for the female die and the verticle bend so the dimples are ugly and the piece is slightly distorted (sorry I don't have a picture). I checked my measurement from the edge to the hole centerline and for the most point I'm right on (3/8").
What have others done? I quess I could file part of the female die away for clearance if I have to but not happy with this solution.
Thanks for any advice.
Jim
RV9A wings
tail done
Old 03-06-2009, 01:51 PM
mburch's Avatar
mburch mburch is offline
Have you tried a small-diameter female die?
http://www.averytools.com/pc-578-17-...mple-dies.aspx
There are certain spots where they come in very handy, maybe this is one?
good luck,
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 03-06-2009, 02:00 PM
Default Sounds good Matt
I didn't know those small dia dies were available. Sounds like a good idea to me. Thanks for the advice.
I did a search and I am surprised there weren't postings about this issue.
Jim
Old 03-06-2009, 02:10 PM
RV10Man RV10Man is offline
Default re: grinder
I ground a flat spot on my dies so they fit close to an edge.
Marshall Alexander
RV10 N781DM
Old 03-06-2009, 02:14 PM
airguy's Avatar
airguy airguy is offline
I originally got the small diameter dies by accident, and didn't even know they were advantageous until I heard people complaining about dimpling. My J-stringers were a non-event. I did grind down a lip on the female die early in the empennage section to give good dimpling close to a bend.
Old 03-06-2009, 02:59 PM
Flying Scotsman Flying Scotsman is offline
Tools were meant to be modified . We have several dies that were ground down, both male and female, to fit tight areas. Better the tool get goobered up than the part!
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
