Old 11-13-2005, 09:16 AM
N62XS N62XS is offline
Default Connections on Wingtip Antenna
Can someone tell me which post to connect the center conductor of the coax to on a Wingtip Nav antenna?
Robby
Old 11-13-2005, 02:37 PM
Sam Buchanan's Avatar
been here awhile
Default connections for Sportcraft NAV antenna
Details here:
http://thervjournal.com/sportcraft.htm
Sam Buchanan
Old 11-14-2005, 06:34 AM
Default Thanks
Thanks for the info.
Old 11-14-2005, 11:15 AM
attson attson is offline
Default wing tip VOR antenna
does the wing tip VOR antenna also picks up the ILS/LOC signal like the cat whisker type
Old 11-14-2005, 12:14 PM
been here awhile
Yes.
Sam Buchanan
Old 08-02-2007, 08:02 PM
AV8rDoc AV8rDoc is offline
Question Archer Com Antenna Connections
Does anyone know which post to connect the center conductor of the coax on the Bob Archer wingtip COM antenna?
Is it the same as the NAV antenna? I took my wingtip off and forgot to label the posts and also lost the original installation diagram/instructions!
Curtiss Stinis
RV-4 0-320/Catto Prop/Lightspeed PlasmaIII/Dynon D-100
San Diego, CA (MYF)
