Old 03-05-2009, 02:17 PM
GeorgeSFNM GeorgeSFNM is offline
Unhappy Halogen Landing light
The light has only one wire and is apparently self grounded. When I connected a 12 Volt battery to it I got not result. Does one have to connect the neg . terminal to another wire and that to a ground? Sorry, I'm a candidate for "Wiring for Dummies" book.
Old 03-05-2009, 02:35 PM
rleffler's Avatar
rleffler rleffler is offline
Yes, you need a complete circuit. In most cases, lighting is grounded through the airframe, which is also connected to the negative terminal of your battery.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
