Originally Posted by Skint
Anyone come across tips or detailed instructions on mounting the wings on an RV7a?
1) slide wing into spar
2) insert bolts
3) install nuts
(it's kinda like those lines in the instructions that say: drill, debur, dimple...)
As Paul Harvey would say, here's the rest of the story -
Step 1 - not too bad if you have a couple of friends help. Don't forget about any wires that need to be run, and be careful of the fuel lines. Be sure the aft spar has been trimmed per the plans (shoulda been done long ago, but just in case...)
Step 2 - can be a bit more challenging. Make sure the actual bolts slide into the parts while they are apart. If they don't fit there, they won't fit when it's together either :-) You already know about starting with 'drift pins' made from hardware store bolts.
Don't forget the washer goes under the head on the lower bolts
On the bottom bolts, don't drive them all the way - get the end just past the spar by 1/16", or else step 3 is impossible!
Step 3 - easy for the upper bolts, but the lower ones are a different story (I narrated my story with a lot of 'colorful' words). I literally superglued the large nuts to a strip of aluminum to hold them in place while turning the bolt until it started. Then you need a ground-down open end wrench to hold the nut while tightening. One of your RV buddies will have this wrench.
Note: there is very little throw room on the head side of those bolts. If you have a pneumatic wrench, it makes it much easier to get them started.
I've done this twice - first with my son on his plane, then on mine a couple years later. The second time was not any easier, but the stress level was lower, knowing what to expect...
