Old 03-03-2009, 04:47 PM
prkaye prkaye is offline
Default orientation of oil cooler
Is there a preferred orientation of Vans' oil cooler (wrt which port is oil return and which is oil outlet)? I see no markings on the unit, and it appears to be physically symmetrical.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 03-03-2009, 07:47 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Default I don't think so
I don't think to cooler really cares which way the oil flows through it. Common practice is to put the inny is the bottom port and the outy the upper port. This way no air gets trapped in the cooler.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 03-03-2009, 08:00 PM
OK, so it doesn't matter which port is up and which is down when i mount the cooler?
Phil
RV9A (SB)
Ottawa, Canada
Old 03-03-2009, 09:01 PM
scard's Avatar
scard scard is offline
Think about all the different orientations that people have mounted oil coolers; side-ways, angled a little this way, angled a lot that way, on the firewall, on the baffle... A lot of airplanes flying just fine for a lot of hours with oil coolers oriented every which way.
Scott Card
CMW E-Lift
Old 03-04-2009, 07:01 AM
Mel's Avatar
Mel Mel is offline
Default Everyone here is right.
The cooler doesn't care about direction of flow. Like Gary says, it's best to keep oil flowing "up-hill" to prevent air entrapment, but not a requirement.
Now, having said that, I'm talking about standard aircraft coolers. There are some aftermarket automotive coolers that call for flow in a particular direction, but they are seldom used on RVs.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
