Old 03-03-2009, 11:30 AM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Cool shunt, wiring and cable protection
Well,
I mount my shunt on firewall, it is wired on P1 (alternator/shunt/cabin).
Now it's time to attach two small wire (18AWG as per plans) to connect the ammeter instrument, BUT .......
.... so I have 2 positive wire that go into the cabin without a protection ......
I think it's better to put, just after the shunt (instruments connection) one protection for each 18 awg wire
what do you think ?
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
Old 03-03-2009, 11:35 AM
DGlaeser DGlaeser is offline
Default Check with Bob N...
That's a good question for the AeroElectric list.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 03-03-2009, 11:43 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Luke-
Use a fusible link on either side of the shunt. B and C sells them here:
http://www.bandc.biz/cgi-bin/ez-cata...7X358218#flk-1
FLK-1 is the part #.
If you don't know what a fusible link is, check out www.AeroElectric.com
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 03-03-2009, 11:53 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Luke - my certified plane (Skipper) has the same arrangment with the shunt on the firewall. There are two cartridge type fuses there also to protect the wires going aft to the ammeter. I don't think it matters what you use, but you should have some sort of protection there.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 03-03-2009, 12:45 PM
flickroll's Avatar
flickroll flickroll is offline
I used this device to fuse both of the shunt/ammeter leads in my -8:
http://www.crutchfield.com/p_669PP61...ch=fuse+holder
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 03-03-2009, 12:52 PM
aerhed aerhed is offline
Default V drop?
Does voltage drop across the circuit protectors affect the ammeter, or does putting protection on both leads cancel it out? Or does it matter?
Old 03-03-2009, 12:56 PM
amilder amilder is offline
The voltage drop should be negligible, since there is almost no current flow through the ammeter
Andrew Milder
RV-9A finishing- canopy
http://andyrv9a.blogspot.com/
