Old 03-03-2009, 04:57 AM
Mike Raviv Mike Raviv is offline
Question Stripping TEFLON /TEFZEL wire
Gents,
There must be a better way (a working way) to strip those tiny teflon insulated wires than how I mess and ruin them. I mean mostly those microscoping wires coming out of trimmer rocker switches and others like those.
And perhaps there must be some better stripping tools than I have (although I have quite a few, including those "automatic" ones).
BTW, I went to a pro to show me the ropes, he was just as good at it as I am.
Help please.
TNX
Mike Raviv
4X-ORV
Going electric.
Mike Raviv, 4X-ORV (res)
s/n 70434
Installing systems.
Old 03-03-2009, 05:46 AM
Jamie's Avatar
Jamie Jamie is offline
Hi Mike:
Indeed, those tiny wires are quite an annoyance. As a general rule, most folks avoid using wire smaller than 22AWG just for that very reason. However, there are times when you *must* deal with them, such as when using the trim rocker switches you mentioned.
The best method I found that works is to carefully score the tefzel with a razor knife (being careful not to nick the wire) and then use the automatic stripper. It worked great for me.
Also on those smaller wires you have to be careful about using any crimping connectors because you can easily break the wires. Anytime I had some of those wires (for example on the trim motors) I used D-SUB pins and crimped and soldered them, then put heatshrink over the connectors for vibration isolation.
Not sure if you have this or not, but if you don't have 'Lectric Bob's book it's highly recommended.
Old 03-03-2009, 09:39 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
I bought one of these strippers.
I have had about 99% satisfaction with it------and the other 1%?? I did not get the wire into the notch before stripping
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-03-2009, 10:14 AM
Greg Arehart's Avatar
What Mike said. I have been very happy with the Stripmaster. Stein sells them but there are probably other places that sell them as well. Note that the best model is slightly different than the model that Lowes or HD sells.
greg
Greg Arehart
N 7965A
Old 03-03-2009, 11:03 AM
fl-mike's Avatar
fl-mike fl-mike is offline
The proper automatic type wire-stripper is the 45-177:
http://www.idealindustries.com/produ...tripmaster.jsp
Or equivalent clone frame with the L-5560 blades.
These blades pinch the insulation rather than cut it. The grit gripper rather than the sawtooth type helps things too.
Check Ebay.
Mike W
Venice, FL
N164WM
Old 03-03-2009, 11:24 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation If you can buy...
Check Ebay.
...the blades on E-bay, they will fit directly into the approx. $29 Stripmaster blue handled stripper from Home Depot...
The Mil-spec wire cutting blades - the 45-2118-1 - are quite different from the commercial from Home Depot. They have a precisely sized "barrel like" area that holds the insulation exactly in place before the cutting edges reach the wire.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Last edited by az_gila : 03-03-2009 at 04:34 PM. Reason: corrected blade part number
Old 03-03-2009, 12:10 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Default No Joy---
The Mil-spec wire cutting blades - the 45-177 listed above - are quite different from the commercial from Home Depot. They have a precisely sized "barrel like" area that holds the insulation exactly in place before the cutting edges reach the wire.
...on the blades on E-bay. I did find the blades from several electronics shops at $80 to $95 My cheap versions of these work just fine thanks
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 03-03-2009, 04:29 PM
az_gila's Avatar
Smile Only if you...
...are lucky on getting everything aligned correctly. Tefzel is tough stuff, and the aircraft wires are made to exacting dimensional standards, the commercial cutters have different dimensions.
Try looking at the wires under a magnifying glass and see if any are nicked.
That would be a reject for Mil-Spec work... but your standards may differ....
Gil Alexander
Old 03-03-2009, 07:09 PM
Sully Sully is offline
Gil is correct if you use the proper mil-spec blades you will never have a problem with nicked wires. I watched ebay closely for a while a scored a set for less than $20 and then put them in the regular stripmaster. They seem to do just fine up to 26ga.
Sully
RV7 N627RS
Moving into Phase 1
Old 03-03-2009, 11:10 PM
Don Jones's Avatar
Default Nope, the standards are high...
...I just worked with them until I could dependably strip without damaging wires. I would love to have some of the real blades and will keep watching E-Bay aircraft supply. It will save time not having to be so careful. Just not going to pay $90 bucks for them I already picked up some DMC D-sub crimpers and the positioners on E-Bay, so this will be something else to add to my wiring tools.
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
