Old 03-02-2009, 07:15 PM
flickroll's Avatar
flickroll flickroll is offline
Default Aileron Pushrod Boot
I have bought the Fliteline Interiors aileron pushrod boot 'kit'. The metal rings have been fabricated and the boot material has been rubber cemented to the rings. Question: what's the best way to attach the rings to the fuselage? I suppose I could drill for #6 screws and attach that way but am curious what others have done. Also, was it necessary to seal between the metal ring and the fuselage to prevent air leakage that way? Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 03-02-2009, 07:52 PM
DGlaeser DGlaeser is offline
Default Aileron seals
I smeared some Goop on the rings and pop riveted them in place. RTV would work just as well.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 03-02-2009, 08:04 PM
Default platenuts and RTV
I used nutplates and #8 screws to attach to the fuse. Sealed with RTV. Pop rivets are probably faster and easier to install. You won't be removing these boots anyway.
Old 03-03-2009, 06:02 AM
flickroll's Avatar
What is 'Goop' ?
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 03-03-2009, 07:36 AM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
Default Goop
Goop is a clear, solvent based adhesive. Great stuff. You can find it at the hardware store as "Amazing Goop", and at the hobby/craft stores as E-6000 adhesive. Shoe Goo is a very close relative.
William Slaughter
Houston, TX
RV-8QB
Old 03-03-2009, 07:41 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Goop is also non-conductive so it is very useful in electrical applications like sealing DB connectors, etc.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 03-03-2009, 07:45 AM
ericwolf ericwolf is offline
Hey Jim, I was going to install pushrod boots, but I was concerned about the relatively small openings on the -8/8A. I thought that the boots were more intended for the side-side models. Does it look like the boots will work well on your -8? If so, I may install them now before I get my aileron pushrods installed.
Eric Wolf
RV-8A Flying since May 2009, 300+ hours
Mattituck IOF-360, WW 200RV Prop
N184EW
Past President, EAA838 Racine, WI
Old 03-03-2009, 08:20 AM
Wallbangar's Avatar
Wallbangar Wallbangar is offline
Default pushrod covers
Do you have the address for Fliteline Interiors......can't seem to Google it. Thanks Wallbangar
Old 03-03-2009, 09:10 AM
Default Abby's website
Here it is: I think she also advertises on this website (or did anyway).
http://www.flightlineinteriors.com/
Dennis Glaeser CFII
Rochester Hills, MI
Old 03-03-2009, 09:53 AM
cjensen's Avatar
cjensen cjensen is offline
I put mine in with #6 screws and plate nuts as well...I wouldn't think they would ever need to be replaced, but you never know...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
