03-02-2009, 04:18 PM
Sam James Wheel Pants Instructions
Can someone please email or fax to me the instructions for the Sam James Wheel pants? I swapped a Van's set with a buddy and didn't get the instructions with them. Just chatted with Sam (who said he could send them), but I have started cutting and can't wait for the snail mail. He said it would be worthwhile getting hold of a set. I think I have it figured out, but it would be nice to see the instructions to make sure I'm doing things correctly. My email address is cccbuntin@insightbb.com or one can call me first (812)207-4587, then I can turn the fax machine on. I would really like to look at them ASAP because I am taking a break from cutting as we speak. Thanks in advance. Dave
03-02-2009, 08:55 PM
I need exactly the same thing. If anyone can PM or email them please let me know.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
03-02-2009, 11:36 PM
Will let you know.
I will let you know if I get a response Sid. Nothing yet. Sam James said he would send them, so if you're not in a hurry, give him a call (860)531-9130.
03-03-2009, 06:29 AM
Instructions
If you don't get a set I can send you at set but it may be tomorrow before I can do that.
Ned
Ned Rose
Punta Gorda, Fl
RV-7A 42TD work in progress
03-03-2009, 06:41 AM
4 vs 8?
I have a set for a -4. Are they the same thing? If so, I can scan and email them but it will be late tonight before I can get it done. I'll check back this evening to see if you have a set by then and if not I'll send you what I have.
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
03-03-2009, 08:02 AM
Thanks everybody. Don emailed me the instructions -- you all are great! Sid, if you email/PM me with your email address, I can fwd the instructions to you. Dave
03-03-2009, 08:22 AM
Don sent them to me as well.
Thanks again Don. Let the sanding begin!
Sid Lambert
RV-7 Sold
11-15-2010, 07:24 AM
I am in need of the SJ wheelpants instructions. Any chance there is still a copy floating around? If so, email them to mike@rvplane.com .
Thanks!
11-15-2010, 07:29 AM
After obtaining a copy of the instructions I found them not to work for my RV-4. The measurements were so far off my wheelpants would have been 1/8" off the ground.
I would advise just using your own instructions. It would have saved me a bunch of time.
I'll send them for reference though.
Sid Lambert
RV-7 Sold
11-15-2010, 08:02 AM
I have them too if needed Mike, but as Sid said, they are awful instructions. I started them, and put them on the shelf for a winter project because I didn't want to get frustrated and down on the airplane when I could be flying...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
