03-02-2009, 02:15 PM
Off/battery/alternator S700-2-10 switch
Can someone show me how this switch is to be wired? I've searched the net/VAF/Aero Electric...I have come up with many schematics, but I don't get the drawing of that switch.
What I need, is someone to lead my by the hand (with a picture of the back of the switch) to show me what wires go where.
Anybody have a pic of this? Single battery, single alternator...positions will be: off/battery on/battery and alternator on.
How???
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
03-02-2009, 02:51 PM
Chad,
I would also be interested in hearing replies on this wiring as I am working on wiring in my plane as well.
I also have a question concerning the split alt/bat switch. However, I do not want to hijack this thread so I will post the question in its own thread here.
03-02-2009, 02:54 PM
Senior Curmudgeon
Chad, look at the drawing in Bobs book. The switch contacts are numbered, and the schematic refers to these.
Z11, is the setup for what you want.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
03-02-2009, 02:58 PM
I don't have time to draw it, but use the EX11 AeroElectric article as a start:
http://www.bandc.biz/switches.pdf
On page 3, it shows the switch types -- 2-10 (on-on-on) is the switch you want. The top portion is the Master contactor control, the lower half is for the alternator. Here is the wiring layout:
#2 goes to ground
#1 goes to the master contactor. This way the master contactor is grounded when the switch is in the middle and upper position.
#3 is unused
#5 goes to the alternator breaker/fuse (5A typically)
#4 goes to the alternator. This is so the alternator is only energized when the switch is in the top position.
#6 is unused.
03-02-2009, 03:05 PM
Senior Curmudgeon
Originally Posted by bullojm1
---#4 goes to the alternator. This is so the alternator is only energized when the switch is in the top position.
Actually, to the regulator, be it internal, or external.
If you have an external regulator, make sure this wire goes to it, and not the alternator.
Mike Starkey
VAF 909
Rv-10, N210LM.
03-02-2009, 03:24 PM
Sorry....I should preface the way I described was for the Plane Power alternator, which Chad is using.
03-02-2009, 03:50 PM
K...so #5 goes to an inline fuse off the main terminal on the Z-11 drawing...are people doing this, or can this be done with a standard 5A fuse in the main bus block?
Also, does the ANL current limiter come in to play with this switch, or is that just on the firewall side?
Man, I was feeling so good about wiring...then I hit a wall...
Chad Jensen
Senior Curmudgeon
Sorry....
No problem, I had no idea if he was using internal or ext------
My comments were more for anybody who was following this thread, and might be confused by it.
Mike Starkey
VAF 909
Rv-10, N210LM.
03-02-2009, 03:59 PM
Either way works.....I chose a circuit breaker off the main bus so I could reset it in flight.
The ANL is strictly firewall forward.
03-02-2009, 04:04 PM
Yeah, I don't want to get in to circuit breakers...my fuse panel will be accessible in flight thru a flip down panel. Can I wire this to the main bus with a 5A fuse, rather than off the main terminal?
That's what I thought...just wanted to be sure...
Chad Jensen
