03-02-2009, 11:29 AM
Finally, I am getting LOP
I don't know if it is that I am starting to learn something or my engine is now broke in, but I think that I achieved a good LOP setting this week-end.
Just a fun flight to get the oil warm and knock the dust off of me. So I was playing around with engine leaning and got the following to work without the engine stumbling.
OAT 45
ALT 1430
TAS 126 kts
MP 21.9
RPM 2310
GPH 6.8
CH 310 295 319 295
EGT 1385 1403 1388 1376
LOP 49
Alright, maybe there is hope for me. Next up when the sky is taller, go up high and do it again.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
03-02-2009, 01:14 PM
More to go!
Hi Kent,
I think you can do even better. My local cruising setting is
20.8 MP 2080 rpm
125-130 KTAS 5.0GPH
If you have a CS prop, crank the RPMs down and the effciency will go up.
You are lower than we are here, that has some effect. As you go higher, it gets even better.
Good luck, let me know if you have questions.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
03-02-2009, 01:37 PM
Hi Pete
Originally Posted by petehowell
Hi Kent,
20.8 MP 2080 rpm
125-130 KTAS 5.0GPH
At what alt are those number for?
I'll try to duplicate them. I do have a CS prop.
Kent
Kent Byerley
Canby, Or
03-02-2009, 03:17 PM
2-5K
Kent,
Ground level is 1K here so anywhere from 2-5K. It seems to vary slightly with density altitude. Higher density alt give slightly better TAS.
Pete
St. Paul, MN
