Old 03-02-2009, 06:07 AM
mburch's Avatar
mburch mburch is offline
Default Fuel pump installation blamed for fatal RV-7 crash
...was the headline that grabbed my attention in the latest issue of the RV Builder's Hotline. Click here for the NTSB report.
Now I'm all nervous, since I had to replace my fuel pump after I got stupid and cracked the casting while screwing in the vent fitting. I knew from the overhaul manual that it can be tricky to get the new pump installed, but it didn't seem to give me much trouble at the time... I just rotated the crank until the pushrod could be raised up, then sort of finagled the pump into place. It didn't really give me any resistance or anything. Honestly the hardest part was getting the safety wire just right.
Should I be worried? How obvious is a mis-installed fuel pump?
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 03-02-2009, 06:57 AM
flybye flybye is offline
Default Engine difficult to restart?
The following line in the NTSB report got my attention. Can someone explain what the recommended method of restart is in this situation? Are the odds of restarting a starved carbed engine any better?
"Pilot's Handbook of Aeronautical Knowledge states that, in regard to fuel-injected engines, it is difficult to restart a hot engine or an engine that quits because of fuel starvation"
RV9a
Old 03-02-2009, 08:53 AM
JonJay's Avatar
JonJay JonJay is offline
Default Should not be an issue...
I have purposely starved my engine in flight. Restart was immediate when fuel flow was re-established. I will let the experts respond to proceedure, but mine would simply be Mixture in, Boost Pump on.
In a Hot Start under this scenerio, fuel has not had time to vaporize and it is not even in the lines to do so if it has been starved. From 5000 ft, the prop should be windmilling well beyond what a starter could do, so restart should be a non issue if there is fuel. I dont understand the NSTB's response in regard to starting being difficult considering the circumstances here.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-02-2009, 11:34 AM
John Clark's Avatar
John Clark John Clark is offline
Default Restart
An inflight restart is not the same as a hot start on the ground. The airflow will not allow the heat soaking that causes problems in injected engines. The windmilling RPM will deliver fuel to the injector (or carburetor) fairly quickly. The NTSB seems to use some canned phrases in reports that don't quite fit the issue at hand.
John Clark
RV8 N18U "Sunshine"
KSBA
Old 03-02-2009, 05:33 PM
Walt's Avatar
Walt Walt is offline
mcb
Matt,
If it went in easy you should be fine, sounds like you did it right. If you don't get the arm up (it usually falls down when you take your finger off it) and then you force the pump on with the bolts you have problems. As long as the bolts went in evenly and easily you should be fine. You should also have good fuel pressure at idle also. I like to crank it around by hand afterward with the plugs out to feel it sucking and blowing which it will do even at that speed and you can also check for smooth operation. Can't say I have ever heard or felt one installed incorrectly but I would think there would be some unusal resistance/vibration or some kind noise coming from the pump when spinning by hand.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-02-2009, 05:53 PM
GAHco's Avatar
GAHco GAHco is offline
Question I little more info please!
I will just be starting my fuselage next month, so I am definitely not ready for the fuel pump yet.
Help me out here, in the injected RV's isn't there a backup electric pump in the system also?
There sure is on certified injected setups.
Do some people skip the electric backup?
If that is the case you might save some $$ but lose your a$$ doing it.
It is a sobering thought to come out of the sky, a deadly lesson in the reliability of gravity verses the reliability of machines, however well constructed.
I feel for the family.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 03-02-2009, 05:59 PM
Dave Cole's Avatar
Dave Cole Dave Cole is offline
Default Boost pump?
What about the electric fuel pump? One of its purposes is to serve as a back up for the mechanical fuel pump. Loss of the mechanical fuel pump shouldn't necessairly result in engine failure.
Dave Cole RV-7 N97DC reserved
dave.cole@cox.net
Started SB April 2004
Hope to fly in 2011
Old 03-02-2009, 08:57 PM
AX-O's Avatar
AX-O AX-O is offline
I am also worried about this. I removed the mechanical fuel pump off my engine in order to install the fuel overflow part from Vans. My engine was already mounted and I could not put the part in due to interferences with the RV4 firewall. I am definitely going to do more research on this.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 03-02-2009, 09:26 PM
frankh's Avatar
frankh frankh is offline
Default No
Nobody leaves out the backup electric pump. Some of us leave out the mechanical pump and go with dual electric (and boy I have yet to find a single good reason for using a mechanical pump..OK resistance to lightning stikes not withstanding).
Sounds like the pilot simply forgot to flip on the electric pump.
I would also suggest an audible fuel pressure alarm from the Dynon draws your attention to the issue.
Frank
Old 03-03-2009, 08:53 AM
osxuser's Avatar
osxuser osxuser is offline
I like the mechanical pump because:
1. it's independant of the system that backs it up
2. I've only seen one failure in 5 years as a professional mechanic, many many more electric failures.
3. They last forever (years wise, our cardinal's is 35+ years old, no issues, same with the canister type boost pump though. Can't be said for the little box-type pump Van's recommends.)
RV4 wing in Jig @ KPOC
RV7 emp built
