Old 03-01-2009, 07:17 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Default Ooooh, ooooh that smell
Can't you smell that smell
I am stumped. On the last half a dozen landings or so just as I pull off of on to the taxi way I smell an odor of burnt rubber. Like a car tire burn out smell. It lasts a few minutes and then it is gone. My passengers have smelled it too. I have taxied back to the hangar,jumped out , sniffed around thre cowl , in the oil door, but no rubber smell. I have taken the cowl off and can not find anything that looks as if it is causing the smell. I have a very normal engine set up. TMX-0360, with Lightspeed and mag. Baffles are clear of all moving parts. The smell started around the 40 hour mark. The only rubber I have under the cowl is some auto fuel line that protects the throttle cable and miture cable plus the Lightspeed crank sensor wire. No obvious burns or melting. Strange that it goes away as quickly as it comes.
Anyone else experience this?
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
Old 03-01-2009, 07:25 PM
aerhed aerhed is offline
Check your tire pressure & gear fairing openings. Extra weight may be burning your sidewalls a little on smackdown.
Old 03-01-2009, 08:00 PM
Default Smell
Have smelled the wheel pants at landing but no odor. However you may be on to something here. I did install the wheel pants not so long ago. Did take them off today and inspected them,No obvious indication of rubbing. I think I will enlarge the openings alittle. Can't hurt. Tire pressures: Nose 30 , Main 35
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
Old 03-01-2009, 08:03 PM
frankh's Avatar
frankh frankh is offline
Default Brakes?
Are you using the brakes and confusing the smell maybe?
Frank
Old 03-01-2009, 08:09 PM
Default Brake smell?
Do aircraft brakes smell like car and truck brakes? If so I do not believe I am confusing the two. If they do smell like rubber why isnt everyone experiencing the rubber smell?
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
Old 03-01-2009, 08:15 PM
Randy Randy is offline
I say track it down. In my experience every new smell or sound is coming from somewhere and it could be important. At least mine have been but I have a very non standard engine setup and have had to chase down my share of bugs. They can be elusive but rewarding to find and you know you have solved a potential problem.
Randy C
Old 03-01-2009, 08:17 PM
Bryan Wood's Avatar
Bryan Wood Bryan Wood is offline
Any chance that it is your shoes? Is your heater on?
Bryan 9A Sold
Beech S35, and daydreams of a Super 8 or a Rocket starting to take over my brain.
Old 03-01-2009, 08:36 PM
tomwebster's Avatar
tomwebster tomwebster is offline
I get a rubber smell from the tires
spinning up when landing. I touch
down at a slower speed now and the
smell doesn't seem as bad.
The tire smoke must come up the
gear leg fairings like a chimney.
You could seal up the leg fairing
if you want. Taking off the wheel
pant should also eliminate the smell
if you want to verify the source.
Tom
Tom Webster (Chox)
VAF-134
Columbus, Ohio
Luscombe 8A/E (sold after 35 years)
RV-7A N462TW (315 hours)
CX4 (under construction)
Friends of the RV-1 http://www.rv-1.org/
Old 03-01-2009, 09:14 PM
bhester's Avatar
bhester bhester is offline
Default Gear leg openings
Tom
Is it a tricycle gear? If so then you have cut outs for the gear legs. Did you seal those cut outs around the gear legs with proseal? I haven't ever smelled rubber. My gear leg opening are sealed. Just a thought!
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 03-01-2009, 09:20 PM
MNAv8or MNAv8or is offline
This might be a dumb question, but are you on the brakes at all when you touch down? I have run into the same problem on certified aircraft and what I tracked it down to was the owner was on his brakes at touchdown. When the wheels would touch they would actually spin on the rim of the tire. This went on for a while to the point where valve stem actually pulled out of the wheel as the tube rotated with the wheel. This might be the issue.
If you only smell it on touchdown then I would go with it is something with the wheels/tires. If you said that you had just installed the wheelpants not that long ago, take them back off and go fly, does the smell come back.
I have run into a lot of aircraft that have a problem, and then after 3 or 4 hours of troubleshooting the pilot/owner says the typical "o yeah I was fiddling with this or that the other day". If you have recently changed something on your aircraft and have an issue that doesn't seem like it would relate, go to the thing you changed first. It may save you a lot of curse words and head scratching..
