Old 03-01-2009, 06:48 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Default First Flight - N719HW
Just a quick note to let everyone know that my RV-7A took it's first flight today. After a few hours of transition training with a local pilot (thanks to Ed McGinty for that!) I calmed my nerves enough to put 1 hour on the Hobbs today.
I have a few squawks that I need to chase down, the biggest one is a heavy left wing. I couldn't let go of the stick or trim it out...any attempt to let go would induce a fairly fast roll to the left. I've already re-re-rechecked my wing angle of incidence and each wing is within .1-degree of each other. I did notice that my ailerons look like they bulge a little bit at the trailing edge. My 2nd squawk could also be caused by this (very light aileron forces). The last major squawk is that my radio (Icom A200) is very quiet. I think I need to turn the gain up a lot!
I do have two minor issues, too. The first was that I heard a slight vibration occasionally, but I think that was caused by the wing-root fairing rubber seal coming loose on the bottom (last 8 inches or so was loose after landing). The other issue is that my EFIS was calling fuel low quite often (probably from sloshing fuel) and I need to figure out how to buffer that.
In the first hour, the rings did not seat...so I've got to continue the full throttle flying until they do. Cylinder head temps were reading between 330 and 374. Oil Temp was a pretty steady 131 F. It was a bit cold today, so I hope that's why.
With no wheel pants or leg fairings I was seeing around 170 mph indicated, and the max RPM was about 2550. I'm sure that'll pick up once the drag is reduced.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 03-01-2009, 06:56 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Congrats!
As to the heavy wing, I had the same thing. Aileron trim wasn't enough; and I had to hold the stick, even though the force to do so was very light. I actually didn't even notice on the first flight.
All it was, was the aileron trailing edges. One was simply a bit fatter than the other. The right wing was heavy, and the fat aileron was on the left. It was probably only a 1/16" difference. A simple squeeze of about 15" at the (left aileron) outboard end, was all it took. The plane now trims perfectly, with both ailerons in trail with the flaps.
L.Adamson ---- RV6A
Old 03-01-2009, 07:14 PM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Default Congrats!
Congratulations on your first flight, Sonny. Welcome to the club.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 03-01-2009, 07:19 PM
Danny7 Danny7 is offline
Congratulations Sonny!
Since i live in Bend someday i'll be able to check out your plane, it's only 3 ish hours away in a fast plane. It is a little more exciting to hear about a plane that i can reasonably assume i'll see someday, vs something in Texas or SC or further east.
danny
nothing special here...
Old 03-01-2009, 08:29 PM
BlackRV7's Avatar
BlackRV7 BlackRV7 is offline
Default Big thumbs up
Congrats. Fun, isn't it
Dana Overall
Richmond, KY i39
http://www.DanaOverallCPA.com
Repeat offender, RV-10 emp
Builder/former owner, RV-7, "Black Magic" Flying
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
VAF #993
Old 03-01-2009, 08:38 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
If you put the Commant antenna on your plane, ditch the gasket for ground plane... ask me how I know.
Sounds like you're in the ball park!!
Congrats!!!!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 03-01-2009, 08:57 PM
airtime's Avatar
airtime airtime is offline
Default first flight
Congrats Sonny. You've built a very fine looking, and now flying RV. I tried sending you pictures but they were to large for your server to except.
Blue skies - Rob Herndon
Old 03-01-2009, 09:07 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Great day for a first flight
Congrat's on the first flight. Looks like we made it a 2-fer today.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 03-01-2009, 09:29 PM
sbarger24's Avatar
sbarger24 sbarger24 is offline
Congratulations on your first flight there Hanger mate! Now I need to get my plane done, so I can tear up the skies along with you.
Steve
Steve Barger
RV-7A slider
Aerosport Power O-360
My RV was born in Reno, but now lives in Grand Island Nebraska
Phase I completed, enjoying Phase II
Old 03-01-2009, 10:28 PM
Rob and Steve, thanks to the both of you for your help. You guys are great...I hope to return the favor!
Thanks to everyone else that replied, too! I'm looking forward to the next several hours of flight time.
Sonny W
Boise, Idaho
RV-7A Flying!
