Old 03-01-2009, 11:24 AM
rkochcyxh rkochcyxh is offline
Post Rudder brake pedals and Plastic block
I'm trying to mount the rudder and brake pedals (WD 655L and WD655R) in the hard plastic blocks(F6116) The pre drilled holes are really tight. Does a person use a hammer to tap them in or should I sand down the WD 655L & R so that the fit just slides together. Also if I tap it together will it become loser with time.
Russel Koch
RV9A QB fuselage
Old 03-01-2009, 11:34 AM
pierre smith's Avatar
Default Hi Russel...
....we just went throught the same thing on our -7 yesterday. If the tubes are rust-free, the fit is still snug but you'd be surprised at how little foot pressure it takes since you've got quite a bit of leverage. Yep, they're snug and sometimes it takes some tapping.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-01-2009, 11:35 AM
JonJay's Avatar
JonJay JonJay is offline
Default Make sure they are not powder coated there
The ends of the weldment going into the block should not be powder coated. This has been a problem in the past. If they are, simply mask off and remove the powder coating with paint remover. This will give you the clearance you need.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-01-2009, 09:11 PM
Sully Sully is offline
Russel Koch
RV9A QB fuselage
On my 7 they were tight but I could drive them on by hand, oh and the holes are not normal to the surface so it went a lot smoother after I got em aligned.
Old 03-02-2009, 05:28 AM
Brantel's Avatar
Brantel Brantel is offline
Yep make sure you take Sully's advice as these are angled to match the shape of the fuse.
Make sure there are no burrs/rough edges on the tubes.
One thing I did was found a socket that was just too large to go into the hole. I heated the block up with a heat gun and inserted the socket. Once the block cooled, I pulled the socket and the brake tubes slid right in and work nice. Don't overdo it with this method as you don't want sloppy holes either.
Good luck.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-03-2009, 05:16 AM
SmittysRV's Avatar
SmittysRV SmittysRV is offline
These blocks are near impossible to put on the rudder pedal tubes with just your bare hands. So I remembered how my Dad would used his rubber hammer to gently put kitchen cabinet parts together with his rubber hammer. Here I put the first Bearing Block on the floor and positioned the rudder pedal tubes over the holes. Then I gently tapped the end of the tubes into the block.
Same thing here. I flipped the rudder pedal tubes over and gently tapped the other block on to the other end of the tubes.
Here my log entry:
http://www.smittysrv.com/more_stuff.asp?ID=586
Smitty
Old 03-03-2009, 07:28 AM
Noel Simmons's Avatar
Noel Simmons Noel Simmons is offline
Default or the other approch
I like to polish the ends of the steel tubing until they slip into the plastic block. I like reduced friction.
Noel Simmons (repeat builder) just ordered my 40th it's an 8!
406-538-6574
A&P CFI EAA Tech/EAA flight adviser
Old 03-03-2009, 03:47 PM
swisseagle's Avatar
swisseagle swisseagle is offline
Default Check dimension first!
Hello
Check first that there is no burr on the plastic and on the steel tube. mesure the dimension of the tube on up to 4 positions, you will find the tube is NOT round. This due to the welding process. I just remove a bit material with a fine file and cloth on the "high" spots, untill the tubes rotate more freely in the plastic, but dont overdoo it!
Also you should NOT use mineral oil as lubricant on plastic, but sorry, I cant remember the right stuff, silicon based or syntetic ... not sure.
regards, Dominik
