Old 03-01-2009, 09:01 AM
hydroguy2's Avatar
Default james cowl w&b
I'm trying to plan ahead(cheap time filler). I'm planning on my modest VFR RV-7 to come in around 1080#, but wonder about w&b issues.
If anyone else(-7) running a IO-360, Sam James cowl/plenum, extended hub Hartzell or WW200rv prop, do you have CG issues?
Old 03-02-2009, 06:48 AM
rose1265 rose1265 is offline
Default W & B
I have an IO-360, Saber extension and Hartzell blended airfoil with SJ cowl. 7's have tended to have a rear CG bias anyway and moving the prop forward has eliminated the problem. My CGs are all within limits. I can send you copies if you would like.
ned rose
42TD
Ned Rose
Punta Gorda, Fl
RV-7A 42TD work in progress
Old 03-02-2009, 07:20 AM
hydroguy2's Avatar
Originally Posted by rose1265 View Post
..... My CGs are all within limits. I can send you copies if you would like......ned rose
42TD
PM sent Thanks
