Old 03-01-2009, 07:29 AM
prkaye prkaye is offline
Default black stripping
Now that I've basically finished the major work on my baffles and Cowl, I'm doing an inventory of all remaining parts, and a to-do list (which of course still has massive items such as "PANEL").
In my firwall-forward kit (I think), there were two lengths of a black rubbery material about .75" wide. One was 4', the other was 12'. What are these for?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 03-01-2009, 07:35 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Check the plans, final assemble section, for the closeout panels that fit between the fuse and the wing, and under the horz stab, and the fuse.
These use a rubber channel piece--------at least on the 10.
Hard to determine with them all bunched up, but I think that is what these are.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-01-2009, 07:37 AM
vic syracuse vic syracuse is offline
Super Moderator
Phil, they look like the wing root rubber stripping and the rubber stripping that goes underneath the horizontal stabilizer.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 03-01-2009, 08:04 AM
Default Thanks! blue foam block
Thanks! almost done my inventory... very satisfying to be able to see all remaining parts... doesn't look so bad.
Another unknown... this blue foam block?
Phil
RV9A (SB)
Ottawa, Canada
Old 03-01-2009, 08:36 AM
Ironflight's Avatar
VAF Moderator / Line Boy
The blue foam block is for forming the cowl-to-airbox extension. A messy job, since it invovles fiberglass....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
