Old 02-27-2009, 04:29 PM
ArVeeNiner's Avatar
Default What fuel filter to use for a carburated engine?
Hi all:
So, I've read the thousands of posts regarding the placement of the fuel flow transducer supplied in the Dynon kit. I came up with before the mechanical pump...no after...no, on the engine...no, in line....ARRGHHH! Then I read a bit about placement of a fuel filter and I came up with after the electric fuel pump....no, before....no, at each tanks output. My head started to hurt!
So, I'm going to start with the basics. If I elect to mess with the fuel lines in the cockpit which have been in place for a very long time (read here that I'd rather not mess with them), what fuel filter do I use upstream of the electric pump? If I decide to put it on the engine side of the firewall, which do I use? I've see on Aircraft Spruce simple $4 inline glass filters much like I have in my VW Thing. I also know there are $200 filters too. With all our nice fuel lines running both in the cockpit and in the engine compartment, do we really want to revert to a simple glass filter with a clamp and a rubber hose at each end? How would you plumb that anyway?
I have a very basic set up. I have the Van's electric fuel pump and a carburator...that's it.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 02-27-2009, 04:39 PM
Originally Posted by ArVeeNiner View Post
Hi all:
First, a question: Do you plan on having a gascolator? If so, it serves as a crude filter.
Second, an opinion: If I planned on using filters, I'd put 'em in the wing roots. Eventually they will need to be changed and if they are in the cockpit, fuel is going to end up being spilled on the carpet, upholstry, etc. Also if (when?) the filters leak, the leaks won't be inside the passenger compartment.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-27-2009, 04:41 PM
N941WR's Avatar
N941WR N941WR is offline
I suggest you build per the plans. There are thousands of RV's flying with a gascolator.
In my case the Dynon fuel flow is after the gascolator and works fine. Check my web site for pictures.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-27-2009, 04:54 PM
ArVeeNiner's Avatar
Yes, I have the gascolator supplied by Van's. So, that can take the place of a fuel filter?
Kelly Johnson
San Jose, CA
RV-9A
Old 02-27-2009, 04:58 PM
N941WR's Avatar
That IS the filter.
Bill R.
SC86 - Easley, SC
Old 02-27-2009, 05:36 PM
Walt's Avatar
Walt Walt is offline
Default Flow Ezy
I've always used a filter after the selector, this protects the electric fuel pump from debris/clogging. The flow Ezy 3ILA works perfect and is available in your choice of elements, I use the 74micron size.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-27-2009, 07:38 PM
ArVeeNiner's Avatar
That IS the filter.
You know, that's what I thought but I started reading about all these other posts concerning filters and such and I started wondering. So is all this filter talk only a concern if you have FI? I think there is some sort of super electric pump that some people put in near the fuel valve that has a filter near it. Maybe you don't need a gascolator for this set up?
The bottom line is, since the gascolator is the filter, it looks like I'm good to go w/o adding an additional filter, unless I want to put one upstream from the electric fuel pump.
Thanks!!!
Kelly Johnson
San Jose, CA
RV-9A
Old 02-27-2009, 08:11 PM
N941WR's Avatar
... So is all this filter talk only a concern if you have FI? I think there is some sort of super electric pump that some people put in near the fuel valve that has a filter near it. Maybe you don't need a gascolator for this set up?
Thanks!!!
IO engines use a high pressure fuel pump and drop the gascolator, thus their need for an inline filter. Also, the UK requires filters on each tank, thus some mount gascolators or filters in each wing root.
Most certified planes run with one simple gascolator, if they have a carb. They have been using them for years and they seem to work fine. BTW, gascolators also work as a water trap, which most filters do not.
Bill R.
SC86 - Easley, SC
Old 02-27-2009, 08:28 PM
Special Delivery's Avatar
Special Delivery Special Delivery is offline
Default Another option
There are many ways to skin a cat... here's what I use on each tank BEFORE the selector valve > here
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
Old 02-28-2009, 02:52 AM
MrNomad's Avatar
MrNomad MrNomad is offline
Default fuel filter inside the carb
There is also a fuel filter inside the carb of my O-360. It's about 3" long, about 3/8" wide, looks like a brass screen that's been rolled, and it receives fuel from the fuel line. It's easily ruined if you do not allow it to center as you attach the fuel line to the carb.
Ask me how I know.
Barry - Tucson
RV9A Superior O-360 (an amazing experience)
Dynon AP Garmin Sensenich F/P
2020 Dues paid. Thank u DR!
