For those who may be interested in an Andair Throttle Quadrant, I have just installed one in a One Design. I know its not an RV, but it will be similar to an RV-3, 4 and perhaps 8. The version I chose had only a throttle handle, but 1, 2 and 3 lever quadrants are available, with and without flap switches on the top of the throttle. Handles are available that are bent the other way for mounting in the center in sbs airplanes. The wires are recessed in the handle. As always from Andair its really good quality - for example the rails that the throttle handle slides between are about half inch angles, but curved, to make sure the handle moves smoothly a couple of small nylon buttons are pressed into the throttle shaft, also the top of the handle is engraved for the flap switches (I know a 1D has no flaps, one switch for PTT and the other for smoke).
Pete
