Old 02-26-2009, 09:46 AM
scsmith scsmith is offline
Default Tip: Improvement to Vans governor bracket
Hi all,
A number of discussions here have noted that if you install Vans governor bracket, VA-153, as instructed, there is not enough room to install the bolt through the control arm of the governor. A shorter bolt would not have the necessary shoulder bearing area.
So, I made an easy modification to mine that solves this problem and seems to work great. I just bent the end tab on the bracket that anchors the control cable housing through an angle of 180 degrees and mounted everything aft of the bracket. Here, assuming it works, is a .pdf file that shows the arrangement:
I made the bend hot with a torch, and I didn't feel it necessary to reinforce the bend with a doubler, but that would be easy to do. Enjoy.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 02-26-2009, 09:48 AM
Default link to .pdf file
well, the image posting didn't display the .pdf, so here is the link, you can go there yourself with a browser and see the drawing.
http://www.hpaircraft.net/rv8/governorbracket.pdf
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 02-26-2009, 09:51 AM
Default governor cable length
Oh, one last thing. On my RV-8, with the delux quadrant, and the firewall pass-through hole as shown on the drawing, the best control cable length I found (independent of this modification to the bracket) is 48".
I have an extra 55" cable if anyone wants one. $30+$7shipping.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 02-26-2009, 07:34 PM
rvbuilder2002's Avatar
I think the 55" is for an IO-360 with a fwd mounted gov.
Scott McDaniels
Hubbard, Oregon
Old 09-12-2016, 07:29 PM
Default Governor bracket mod and install
This is a thread-bump, since I couldn't figure out how to copy the link url to add to another thread. Lots of people are in the middle of installing/replacing governors right now so I think this should be handy. Works great.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
