Old 02-25-2009, 09:13 PM
glenn654 glenn654 is offline
Default antenna question
When setting up an a/c with dual comms, is it possible or practical to use a single comm antenna? Since you will only transmit or receive on one comm at a time it seems possible.
Glenn Wilkinson
Old 02-25-2009, 09:32 PM
fast_flyer fast_flyer is offline
I had the same question! It does work a friend of mine tryed it. but from my understanding when you transmit the power travel's up to the other radio and can damage it. I was told go with two antennas. thats what I'm going to do one out the belly and one in the wing tip.
Old 02-26-2009, 05:36 PM
avee8tor13 avee8tor13 is offline
Default struggled with the same question
I asked the same question and finally decided to go with a belly antenna for comm1 and a top of the fuselage antenna for comm2. The antenna coupler is just a little cheaper or about the same price as a com antenna. Just run some wire and you have two independent comm systems.
I wonder if one can get a switch to switch the antennas where one can transmit on antenna 1 then switch it and transmit on ant 2?
Be a quick way to ck a weak radio or antenna.
Best of luck.
