Converting engine from B1E to another Cert. Model
This is a fairly easy process. You can go to the FAA website and look up the Type Data Certificate for the engine model you are converting (B1E.) If the engine has the same certificate number as another p/h IO-360 with a vertical sump such as a B1B, B1D, B1F, etc., etc., you can change the sump and keep the engine as a certified conversion.
Of course, the change will need to be completed and signed off by an A&P or certified repair station. The appropriate data plate correction and logbook entry will need to be made.
Good luck!
Rhonda Barrett-Bewley
Reason: remove sentence frag
