Old 02-25-2009, 09:33 AM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Default Carb to sump Torque Value??
Anyone know the torque value for mounting a MA-4-5 to a 0-360 sump ?
I have been searching and I can not find it.
Got to love the service at Mattituck. 204 inch lbs or 17 foot lbs.
A email to mahlon and 5 minutes later the answer.
Thats service
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
Old 02-25-2009, 09:35 AM
Brantel's Avatar
Brantel Brantel is offline
On "How It's Made" it looks like the guy in the factory used the GOOD'N'TIGHT method to torque these
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 02-25-2009, 10:28 AM
osxuser's Avatar
osxuser osxuser is offline
Yeah, it's pretty much impossible to get a torque wrench on those unless you have a high dollar snap-on job with the interchangeable heads. (I have one, but only a couple of the heads for torquing props... $40+ a head). I just torque them until they are 'tight'. By this time in the build you should have a decent feel for tight enough. Make sure you put in the lock washers!
RV4 wing in Jig @ KPOC
RV7 emp built
Old 02-25-2009, 10:49 AM
I had mounted them before but I forget what the torque was. Pulled the carb to get the floats changed. Sent it to Volare. They turned it around in 4 days.
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
