The unit on the strut is easily in the field of view of both occupants and the display is so large that it does not require a lot of refocusing to cross check track and situation. Fitting is a problem in my airplane but there are more important hurdles I had to overcome to make the unit usable by me. They were:
- I must have my approach plates and charts on my left kneeboard - I cannot change how I fly and risk procedural confusion to accomodate the unit.
- I have to have my flight plan for dead reconing, pilotage and radio navigation and ATC clearances on my right kneeboard for the same reason as above.
- I have to have unobstructed visual and physical access to my fuel controls on my center console (two valves for main and tip tanks)
- I have to have freedom from objects interfering with comfortable seating and entry and exit.
These are the reasons I took the hardware to the airport today and made a fit check. I was very very plesantly surprised. Currently I have my little GPS 90 down between the cushions on its little modified mount and I use it for some cross checks of stepdown fixes etc. since I only have one VOR/LOC/GS and an SL-60 GPS with a MAP 360 display. There has been no spatial disorientation for me but I have experienced it in another situation and I understand your concern. When I glance at this television sized unit right there below the engine controls I feel nothing but relief. Other pilots with different practices and procedures will probably feel differently - I just can't visualize a problem with this placement.
Bob Axsom
Originally Posted by jferraro16
Bob--
Are you at concerned about the "heads down" aspect of this set-up? Spatial disorientation in actual instrument conditions, visual diversion during VFR.
Unless I don't understand what you're considering, I just wonder about this idea, even if it fits great.
Best-
Joe
