Old 02-22-2009, 11:51 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Question alternatives to Vans Odyssey PC680 Battery Box Kit?
Hi - I'm looking for alternatives (that others have sucessfully used) to the $50 steel Vans Odyssey Battery Box kit. Mainly for weight savings, and not looking forward to cutting holes in the steel box.
I see that ACS sells a "Hold Down Bracket" for $38, but I don't know what it is made of. They also sell the steel box for $22. You can see both here
There are some forum references to an aluminum box for the PC680, but I can't find it anywhere.
Does anyone have any experiences to share, hopefully with pictures? I need to place an order soon and don't know which way to go.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 02-22-2009, 12:19 PM
Greg Arehart's Avatar
Dave,
I don't have any off-the-shelf suggestions, but making a battery box out of aluminum should be a simple task. If you have access to a sheet metal bender or box bender, it would be even easier. You've built enough airplane to know how to rivet such a box together, I'm sure. Might be worth powder coating or dipping in rubber coating (like used for tool handles - buy a can at the local hardware) for corrosion protection, although it looks like the odyssey doesn't have leak issues.
greg
Greg Arehart
N 7965A
Old 02-22-2009, 12:35 PM
RV7ator RV7ator is offline
Shop on line for a PC680MJ for the lowest to-your-door price. Then slip a thin knife between the battery and the box to cut the blobs of silicone that glue the two together. Modify the box.
I'm certain you'll come out cheaper than buying separately and/or from the aircraft suppliers. Weight forward of the c.g. is a good thing in a 7 and 9; gives you more c.g. range aft for loads.
Never heard of an Al box for sale.
John Siebold
Old 02-22-2009, 04:53 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Default How about this?
http://www.odysseybatteries.com/accessories/pc680hd.htm
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 02-22-2009, 05:08 PM
RV6_flyer's Avatar
Found it for $38.95.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-22-2009, 06:04 PM
mannanj's Avatar
mannanj mannanj is offline
Default Box
Why not modify the Van's battery hold down supplied with the kit? I did by adding an aluminum angle to the bottom of the tray and moving the tiedown bolts to center on the Odyssey.
Doesn't cost anything and is probably as light as the steel one with holes.
Email me at--- mannanj at windstream dot net--- and I'll send you a pic of how I did it. (I really need to learn how to attatch photos here.----Maybe someday!)
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 02-22-2009, 07:12 PM
Thanks guys - I think that aluminum bracket is the same thing that Spruce is selling for $38.75, except the ACS one has the optional "textured black coating".
Looks like it wraps around 5 sides of the battery - to get the battery out I think you'd have to loosen / remove the 6 screws holding the thing to the firewall. Less than 1 pound is sure attractive, though.
Has anyone used one of these yet? Got a picture?
dave
Marion IA
Old 02-22-2009, 08:13 PM
mannanj's Avatar
Default Box
I guess the new Van's box is different from the pre-odyssey era. Sorry.
LAUS DEO
VAF788
Old 02-22-2009, 09:55 PM
Hi Mannan - I'm not sure if it is different. It looks like there is a battery tray included with the fuse kit (DWG 31). It is for what looks like a regular lead-acid battery. It mounts on the front LEFT side of the firewall. It is an open tray, held to the firewall with some pieces of angle (about 7 total). I didn't realize it, but I actually have these parts. I can't see what type of battery this is for, but it is shown with filler caps.
Is this the mount you modified for the Odyssey? If so, I'd love to see the pictures.
DWG 31A shows the optional Odyssey mount, which is the steel box. It mounts on the RIGHT side of the firewall.
I like the idea of the <1 lb. aluminum box, bolted to the firewall. I have to figure out how to bolt it on. Hopefully someone else has done this before...
Marion IA
