Old 02-20-2009, 11:01 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Oil Pressure Orifice Size?
Quick question -
I am building up an AN816-4D as a restrictor to mount in Louise's engine for a new oil pressure sense line - I blocked it up with an appropriate sized rivet, and now need to drill a hole through it - any idea what a good orifice size is?
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-20-2009, 11:04 AM
mburch's Avatar
mburch mburch is offline
Paul,
According to their website, the restrictors Van's sells have a 0.040" hole.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 02-20-2009, 11:19 AM
Ted RV8 Ted RV8 is offline
Paul, Going from memory here so use at your own risk!
I was told by Bart at Aerosport to drill about an .020 diameter hole but he also said it's pretty tuff to do and he was right! It's also tuff to find a .020 drill which is #76 drill.
Again going from memory I believe I ended up drill an .032 hole which is a #67
These drills break really easy, even in aluminum!!
Good luck
Ted
Old 02-20-2009, 11:40 AM
vic syracuse vic syracuse is offline
Super Moderator
Paul, I just used the smallest one that wasn't broken in my box of numbered drills. 60 if you still have it, but anything in the 50' will work. Use a dremel on high speed to drill it. They break to easy if used in a regular drill.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 02-20-2009, 11:42 AM
scard's Avatar
scard scard is offline
"Machine Screw" length drill bits also help. They are much shorter and hence stiffer across the entire size range.
Scott Card
CMW E-Lift
Old 02-20-2009, 11:47 AM
Ironflight's Avatar
Originally Posted by vic syracuse View Post
... the smallest one that wasn't broken in my box of numbered drills. 60 if you still have it, but anything in the 50' will work. ...
It's amazing how often I have used that criteria in drilling a small hole...
Thanks folks, I'll see what's left in the small end of the box and chuck it up in the Dremel.
Paul
Paul F. Dye
Old 02-20-2009, 04:09 PM
Harold Lanfear Harold Lanfear is offline
Default If you need small drills...
you can get them at any hobby store. I just bought a full set for about $4.00 after I dropped my old set and lost a lot of what wasn't already missing
Harold
Kitfox sold 2010; RV-8 85% and moving at the speed of a used Edsel
Old 02-20-2009, 09:00 PM
I have the AN816-4D's from Vans, one for fuel pressure and one for oil pressure and I believe they are drilled out at .040.
A smaller hole would be better. The first time I pressurized the fuel system pressure should have been 25 psi but settled down at 8 psi. I had failed to tighten the -4 pressure line at the pump fitting and it sprayed fuel all over the firewall and aft side of the engine. What a stupid mistake that was.
It was luck, one more time, that the whole thing did not blow up with the master relay and battery right there.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 03-25-2009, 08:03 PM
Joe Joe is offline
Default Rivet? What Rivet?
Now that the hole size has been more-or-less specified, would someone please explain what size rivet is used and how? Is it pressed in or what? And which end of the AN816-4D?
Joe
Joe Dubner
RV-8A
Independence, OR
Old 03-25-2009, 10:06 PM
Norman CYYJ Norman CYYJ is offline
If you have a chuck that will close down small enough in your drill press use it the bits don't break so often.
