Ok, following the suggestion from Patrick, I removed the outer skin and re-checked rib flanges for the correct bend. I noticed a small under-bend on the first three ribs (counting form outboard). I had to slightly bend the flanges a little more and add a little touch-up with the fluting plier in a couple of spot.
Re-clecoing the skin with a cleco in every other hole, I noticed the improvement was really visible, but a little of oil canning was still there... I reclecoed the skin with a cleco in every hole and I ended up with a skin tight like a drum!!!
So, I'm (almost!) sure I will have no more problem once the skin will be riveted!
