Old 02-19-2009, 08:26 AM
prkaye prkaye is offline
Default OK to move lightspeed connector
My engine came from Aerosport with this black module that I think is part of the ignition system ("ignition coil"?) mounted on the top of the engine throught he crankcase bolts. As you can see from the picture, because it is mounted near the back of the engine (along the top), it is directly in the way of the baffling aft center support bracket. Will it be OK for me to move this little black unit forward by about 5 inches (to the crankcase bolt halfway along the top of the engine)?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 02-19-2009, 08:45 AM
Norman CYYJ Norman CYYJ is offline
Move it forward to the bolt where the lifting hook is. You can put those coilts anywhere you want to.
rvmills's Avatar
rvmills rvmills is offline
Phil,
Those are the ignition coils for a Lightspeed Ignition, just as you suspected. I looked at Klaus' website, and there are pictures of various installations here:
http://www.lightspeedengineering.com...ionInstall.htm
Some of the pix show the coils mounted forward of the baffles, on the crankcase (or so it appears).
Mine (bought-flying RV-6/IO-540 with plenum) are mounted on the firewall, and the spark plug leads penetrate the baffles. Looks like there are several ways to skin the cat, but if you want to call Klaus to make sure, his number is (805) 933-3299, and his e-mail is in the "contact" section of the above site.
Hope this helps!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 02-19-2009, 08:53 AM
Cool, thanks guys. Looks like with a small clearance notch cut into the baffling centre bracket, I can get away with moving the ignition module forward just one crankcase bolt position (i.e. not all the way to where the hook is, but between where it is now and where the hoook is).
Phil
RV9A (SB)
Ottawa, Canada
Old 02-19-2009, 10:38 AM
flion's Avatar
flion flion is offline
I actually made a doubler for the bracket which also acted as a mounting bracket for the coil and raised it up enough I didn't have to notch and got better clearance for the coil (remember, you have to attach wires to the coil). You don't want it so forward that the lifting ring interferes with the plug wires or so high that it would be too close to the cowl. On a related note, I found it handy to make my own plug wires using parts from Summit Racing, as the supplied ones did not work well once I repositioned the coil.
EAA Technical Counselor #5357
Old 02-19-2009, 01:35 PM
odlee odlee is offline
Default Here is a baffle front and rear view
method that worked. Mounted on a bracket which moves the module forward. Your choice.
Old 02-19-2009, 04:10 PM
Rion Bourgeois's Avatar
Rion Bourgeois Rion Bourgeois is offline
Default You can also fabricate another bracket to move the coils forward
Old 02-19-2009, 04:18 PM
Default second try at inserting image
//http://profile.imageshack.us/user/rionbourgeois/images/detail/#136/lsicoilmountingbracketol8.jpg
Old 02-19-2009, 04:27 PM
Default third try at inserting image
http://profile.imageshack.us/user/ri...bracketol8.jpg
Old 02-19-2009, 05:51 PM
Default Blast tubes
Rion what kind of tubing were you using for cooling the mags?
