Fuel and oil pressure are sent to the manifold via hoses. The oil temp is sensed off the engine via a temp transducer, so it is not necessary to use the manifold for that. Not sure what you mean about the "red" master on arning switch. If you mean the pressure switch that turns on the hobbs when the engine is started, then that would be screwed into one of the holes with the oil pressure transducer and hose. This is assuming a Lycoming engine. Other engines may or may not be the same.
Here is a photo of where mine is. It is located on the firewall where the forward fuselage rib is attached to the firewall. You can see the blue manifold just behind the blue vacuum hose. I only used two sections of the manifold. There are three, with three ports in each section. One could be used for engine manifold pressure. I used another method.
The plans in the FWF kits, and some accessory kits will have standard diagrams for most of these items.
Hope this helps,
Roberta
