Old 02-16-2009, 01:03 PM
ericwolf ericwolf is offline
Default Trick to installing wing root fairings?
I fitted the wing root fairings and have 1/4" gap to the fuselage. I'm having a heck of a time getting them installed with the rubber seal however. I didn't have much trouble with the flat top piece, but the piece that wraps around the leading edge seems impossible to get on. Thoughts?
Eric Wolf
RV-8A Flying since May 2009, 300+ hours
Mattituck IOF-360, WW 200RV Prop
N184EW
Past President, EAA838 Racine, WI
Old 02-16-2009, 01:13 PM
kevinh's Avatar
kevinh kevinh is offline
Use a few bits of electrical tape to hold the back of the channel in place while installing. Getting it on the first time is a bit of a trick, but a few weeks on the plane it takes a set and reinstalling the next time is easy.
I don't recall my gap but it was <1/4"
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 02-16-2009, 01:26 PM
pierre smith's Avatar
Default Hi Eric......
.....try placing the rubber against the fuselage an inch above the wing and hold it firmly against the fuse. As you lower it onto the wing, it'll fold upwards from the friction against the fuse...have a screw/screws handy to go in immediately.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 02-16-2009, 01:43 PM
tomwebster's Avatar
tomwebster tomwebster is offline
It might be a trick:
I had trouble with the rubber seal when
it was (what I thought) mounted
correctly.
When I turned it over so the flat side
was up, it worked much better.
Tom
Tom Webster (Chox)
VAF-134
Columbus, Ohio
Luscombe 8A/E (sold after 35 years)
RV-7A N462TW (315 hours)
CX4 (under construction)
Friends of the RV-1 http://www.rv-1.org/
Old 02-17-2009, 08:04 AM
Thanks guys, I'll try the electrical tape trick. I was using the method that Pierre describes, but it wasn't working around the leading edge curve.
Eric Wolf
N184EW
Old 02-17-2009, 08:10 AM
Jamie's Avatar
Jamie Jamie is offline
Yep, once this stuff is 'trained' to go on correctly it will go on with no problems in the future. Mine was a bear to get right too, but now it's pretty good.
Old 02-17-2009, 08:54 AM
647jc's Avatar
647jc 647jc is offline
I also used Pierre's technique and additionally I misted the fuselage side with a bit of soapy water, very weak solution like what you would use to put a decal or vinyl on. The soapy water helps the compressed rubber to side against the fuselage side into proper place.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 02-17-2009, 09:32 AM
trib trib is offline
Is there any typically accepted gap between the fairing (w/o rubber) and the fuselage? I see you had 1/4". Dan Checkoway mentioned 1/8" in his site. I'm cutting mine now and would like to find out what is best.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 02-17-2009, 10:40 AM
rocketbob's Avatar
1/8" is plenty.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 02-17-2009, 11:47 AM
I also found this thread regarding installation and adhesive to hold the seals on - http://www.vansairforce.com/communit...d.php?t=38693&
I actually trimmed the top fairing to 3/16" and the other one to 1/4" because I had trouble getting it on. Now I wish that I had stuck with the 3/16" for everything. I guess I'll see how well it fits once I get it on and decide if I need to attempt to make a new one or just glue it on and live with it. It is only on one side - the other side is still untrimmed.
Eric Wolf
N184EW
