02-16-2009, 10:46 AM
Step Installation Question
Hi folks:
Quick question, I am preparing to install my steps. The instructions say to cut a 1.5" hole in the fuse side, but if I only cut a 1.5" hole in the fuse skin, the weld on the step mounting plate will interfere with the hole, and the step mounting plate will not fit flush with the fuse side. I think I need to open the hole up at least 1/8" more, either that or grind down the weld. Grinding the weld it seems would compromise the strength of the part.
How have others handled this, and how has your solution performed?
Thanks!
Antony
Antony
RV-7A
Empenage complete, wings complete, tip-up canopy complete, starting wiring ...
02-16-2009, 10:52 AM
I opened the hole so the step fit without interference. Your Dremel is your friend here and when cutting the hole for the flap push rod.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
02-16-2009, 01:38 PM
Step installation
I approached it similiarly. The hole won't end up exactly round because the fuselage starts to taper there. You can see my progress at the link below. Follow by moving on to subsequent log entries.
http://www.mykitlog.com/users/displa...=25804&row=104
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
02-16-2009, 01:55 PM
Antony,
And, there are some of these steps that have a too-long tube that will need to be trimmed down a half inch or so to fit into the floor ribs properly.
greg
Greg Arehart
N 7965A
02-16-2009, 02:10 PM
Great!
Great stuff guys. Thanks so much, this is just what I was looking for.
Antony
RV-7A
02-16-2009, 05:06 PM
installing step
Antony ; consider putting proseal between the back side of the steel plate and exterior skin to keep out moisture and eliminate the possiblity of corrosion being the two metal are dissimilar.
This tip was given to me after it was too late, I now wish it was in there !
9-A slooow build- DONE & LOVIN IT !!
Nevin Miller - north Idaho
02-16-2009, 06:14 PM
Great tip!
Nevin:
That's a great tip! Thanks very much. I will do that.
Antony
Antony
RV-7A
02-16-2009, 07:28 PM
Originally Posted by Greg Arehart
Antony,
greg
Or too short. Mine were short a small amount, so I had to make a spacer for each one to get it all the way to the floor rib on each side.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
02-16-2009, 08:06 PM
Rethink the proseal. I had cracks develop on my step which required that I remove it.
