It looks like you have some sort of brass fitting for the vent, is that right? I'm looking at the AS catalog right now and I don't see that fitting. Where did you get the plastic line from the vent? Is that from Orchard Aircraft Supply?
Hi Kelly,
Actually, I think that fitting was in the finishing kit from Van's. When I ordered the finishing kit I got a listing of the parts from Van's before ordering and left off what I already had but I believe that vent fitting was in the kit and I just used that rather than a standard AN fitting.
Van's site says the fitting is for the RV-4 setup since a standard AN fitting won't clear the firewall; but it works fine in my 6A too....
Looks like the p/n is F OVERFLOW PLUG 1/8" and it sells for $9 on Van's site at:
http://www.vansaircraft.com/cgi-bin/...erflow-fitting
You could probably make a similar fitting or use one of the standard AN fittings that works for your setup.
In my RV, the installation and routing of the vent line plastic tubing into aluminum tube that passes through the lower firewall flange is per the drawing that came with the finishing kit. There was a short length of aluminum tubing for the end piece and I think some plastic tubing too in what I got from Van's, but I had to make a couple of the aluminum tube pieces before I got it right so I used what I had left over from my brake line installation for both the plastic tube and the aluminum tube at the bottom.
Edited comment to above: in looking at my pictures closer, I think the aluminum tube at the bottom is smaller than the aluminum brake lines as it fit into the 1/4" plastic tubing....I'll have to check the drawing and look at the line when I'm at the hangar next but you should be able to verify on your drawings.
Along with all the critical hoses fwf, I check that line everytime I pull the cowl (fairly often as I'm still in Phase I testing) just because the plastic line and tie wrap setup seemed a little "less robust" than everything else I put in, but it's holding up fine so far and is per Van's design...
