I will be hanging the engine soon. At the moment I am checking what I can connect/install on the engine before it is hung. Obvioulsy some of these coonections are for oil cooler and oil-pressure, but what is what?
First picture: what is this stud for, in the middle of the picture, with the castellated nut on it? (RH side)
Second picture: What is the connection for, in the next picture, plugged with the square brass plug on the left of the oil filter?
Third picture: What are these for on the next picture:
- Between the Oilfilter and the SD8 alternator (orrange), is this the pick-up for a mechanical Tach?
- What is the connection on the oil filter housing for? The one with the white plastic temp. plug in.
- What is the connection for, at the bottom of the picture, with the brass, square plug in it? (bteween where the magnetos used to be)
In the fourth picture, the two plugs, at 90? of each, are the oil-pressure ports, I assume. Use either one of these, right? I suppose rear facing one will be best, because of less interference with the engine mount?
As always, thanks a lot for your reply.
Kind regards,
Tonny.
