Go Back   VAF Forums > Model Specific > RV-4
  #451
Old 12-22-2018, 10:10 AM
flyride flyride is offline
I now understand your painting strategy.
It's going to take a long time to finish at this rate.
Tank
Old 12-22-2018, 10:25 AM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Cool
Paint is over rated
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
Old 12-22-2018, 10:28 AM
Michael White's Avatar
Originally Posted by Dayton Murdock View Post
Paint is over rated
Not on your gorgeous red 4 it isn't.
(Sorry for the thread drift Axel...back to you now...)
Moose
VAF #136
Old 12-23-2018, 07:51 PM
Scott Hersha Scott Hersha is offline
Axel,
Thanks for posting all the updates to your RV4. I think you have the perfect setup now for an RV4. I had an RV4 with a carbureted O-320 and a Catto prop that was the nicest flying RV I’ve had (I’ve had four) - and the most affordable. The best improvement would have been a constant speed prop, but that would have involved making those blood thirsty cuts in the firewall step. I built another RV8 instead. I just installed a Whirlwind 200RV on our new RV8 (my third on an RV), and I also recently installed dual E-Mags.
My question for you is, what benefit have you realized by having the EI Comander? I’m not racing my plane, and don’t plan on any competition aerobatics. Is the standard B curve sufficient? I have an IO-360 with 9:1 pistons and an Av star FI system. Event though I can’t adjust my timing in flight, I don’t know if I need to. Maybe you haven’t flown yours yet, but if you have, please let me know the advantages of the EI Comander.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 12-23-2018, 08:46 PM
AX-O's Avatar
AX-O AX-O is offline
Originally Posted by Scott Hersha View Post
Is the standard A curve sufficient? I have an IO-360 with 9:1 pistons and an Av star FI system. Maybe you haven?t flown yours yet, but if you have, please let me know the advantages of the EI Comander.
Thank you, I hope all this work is worth it.
I have not flown yet. will let you know how it goes. I can tell you that it was very easy to send a curve compared to the previous way of doing it.
Hopefully this wont start a thread drift. These types of questions are like asking what kind of primer to use
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 12-23-2018, 09:46 PM
N941WR's Avatar
N941WR N941WR is offline
Not to drift this cool thread, check your PM's.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-25-2018, 01:10 PM
sblack sblack is offline
What is the advantage of a CS prop for racing? Or did you add it for a different reason? I would have thought that for a race there is only one speed range...balls out!
(Ps...balls out is a reference to the brass balls on a steam engine governor. Nothing to do with anatomy, just in case anyone might be offended ��)
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 12-25-2018, 05:44 PM
AX-O's Avatar
I did not do it for racing. I expect to loose 2-3 knots top speed. That been said, One of the things that killed my speed around the track was exiting the pylons with low RPMs. The RPM would drop and i would loose a lot of speed. It would take some time to build the RPMs back up. and by then I was in another turn. So my time around the track may be slightly afected now that the RPM would remain constant.
Not sure I will be racing at Reno with this plane any more. The plane just gets beat up and a non-boosted or non-nitrous RV in the sport class is not guaranteed a spot in the field of 36 now.
I have mixed feelings about this convertion. However, All this may go away once I satrt flying. TBD at this moment.
Axel
Old 12-27-2018, 12:11 AM
skylor's Avatar
skylor skylor is offline
I think you will love the constant speed prop!
Skylor
Old 12-27-2018, 10:41 AM
rv7charlie rv7charlie is offline
Skylor
Having gone from planes with, to planes without, I agree. What keeps me away these days is simple: Money. Just can't justify the expense the complexity brings with it, for the amount of flying I do.
