It depends
On what the tempature of your shop is, the kind of catalyste you used, slow-medium-fast, direct sunlight speeds things up. I would think things should be solid in no more than 24 hours. I am far from an expert but hopefully Dan Horton will chime in, he is very good with fiberglass and has made some great posts about fiberglass on here, search DanH and you should find some good tips.
Randy
8A Finishing, FWF
Reason: Adding Info
