Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 02-13-2009, 10:36 AM
cjensen's Avatar
cjensen cjensen is offline
Default Need some help...Garmin 295 wiring
I have the hard wire for the Garmin 295 that is getting panel mounted. The manual for the unit shows what each hole in the plug is for, however, my tester plugs are too thick to get in the hole to check for continuity to tell me which color wire is power, ground, data in, and data out. Here's the pic...
I have white, black, red, and brown (can't see the brown in the pic).
Is there anyone that has done this that can tell me which wire is which? ...Or am I stuck buying a new tester?
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 02-13-2009, 12:07 PM
rich rich is offline
Chad,
If I remember correctly,
RED = 12v (use 1 1/2 amp fuse)
Black = Ground
Brown = Data Out (Autopilot)
White = Data In
Good Luck,
Rich
Old 02-13-2009, 12:13 PM
N941WR's Avatar
N941WR N941WR is offline
Chad,
Check out this thread:
http://www.vansairforce.com/communit...ad.php?t=14479
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-13-2009, 01:00 PM
cjensen's Avatar
I saw that, but wasn't sure if the wiring was the same for the 295...I guess I can assume the red and black wires are the same for the 295 though. Won't be using the data in/out for now, so if red and black are what I need, that'll take care of my problem.
Chad Jensen
