02-14-2009, 12:06 PM
Originally Posted by L.Adamson
I have my secondary & redundant control system all worked out...........
In case of joystick failure. I'll just leave the wireless passenger stick, firmly bolted in................no matter how fat the passenger is!
L.Adamson --- RV6A
Gotta agree with ya there Larry...mine's staying put too. My kiddos and friends would scream foul!
But mine's not wireless...that's pretty hi tech...what'd ya use, 803.b or .g?
Bob
02-14-2009, 12:30 PM
Bob
Actually, in my case,...............being "wireless", means the passenger PTT is on the panel!
L.Adamson --- RV6A
02-14-2009, 12:56 PM
below pivot
Why not put the wire exit hole BELOW the pivot point? This way there are NO elevator loads, only aileron loads which are, I would think, considerably less.
Bevan
02-14-2009, 05:52 PM
Alternate hole locations
A few of you have asked about putting the hole in a better place in the stick. The analysis I did had the hole in just about the worst possible location, and it was 1/2" diameter to boot.
I have a couple comments about alternate locations: First, consider putting the hole in the side of the stick rather than the front or back. This is simply because the roll forces on the stick are less than the pitch forces. I'd guess off-hand that the roll forces are maybe 2/3 or even 1/2 the pitch forces. That would result in a corresponding decrease in stress around the hole.
Second, placing the hole further UP the stick is better than closer to the pivot. The controlling distance is what's measured from the hole to the application of load, ie the stick grip. Locating the hole higher up on the stick does give us some other problems to deal with and those have already been discussed.
Finally, there's no substitute for an actual test of this part. The FEM analysis is pretty and it has merit for showing how stress is distributed. BUT its hard sometimes to draw the correct conclustions from this type of analysis.
I'll try and get a few tests in for y'all.
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
02-15-2009, 06:25 AM
Originally Posted by chaskuss
Mat,
Another solution would be to run the wiring harness externally along the outside of the control stick. McMaster-Carr and MSC sell nice spring steel clips for this purpose. The clips are shaped like a C, with a bulge (for the harness) in the middle of the C. Two or three clips (or other securing methods) will keep the harness in place.
Charlie Kuss
Charlie,
Do you have a part number or a better idea of what these are called? I'm interested in something like this, but I've searched all over McMaster and MSC's websites and I can't find them. Obviously I'm not using the right search terms.
PJ Seipel
RV-10 #40032
02-15-2009, 07:08 AM
loads below pivot point
Hi all,
Bevan
The elevator loads aren't gone below the pivot point (we are still talking about the RV-8, right?). There's a steady rise of moment from the point you apply force to the stick to the pivot point, then a steady decrease to the attatchement point of the elevator pushrod. The shearing loads change direction and increase at the pivot point. The aileron forces however should be gone below the pivot point (the point where the stick is bolted to the welded construction, see rick's pics).
Still, drilling holes in this area of the stick scares me a lot, I'll have a close look at mine (side by side) when I come to that task.
Kind regards,
Mario
Mario from Aachen, Germany
RV-7, emp. done, wings close to being ready for inspection, canoe flipped and parts of the finish kit in just about every room of the house
2019 contribution sent - thanks for this awesome space DR
02-15-2009, 09:58 AM
try fig 4-38, p 4-172
Originally Posted by sprucemoose
Another interesting idea, except I don't find this in AC43-13. Do you have a page number?
RV-8 KFYE
Memphis, TN
donation given
02-15-2009, 12:44 PM
This figure deals with using a split sleeve to repair a damaged tube section. I was thinking about this as a way to reinforce the area in the stick where the hole would be, but it seems like an awfully heavy, overkill way to do it.
I think I have a better idea now after re-reading the post. What you are talking about is making a T-joint right over the hole in the stick (similar to putting holes within a cluster joint for line oil to penetrate) then cutting off the vertical leg of the T after welding, so that only 1/8 inch or so remains. This seems like a good alternative to welding on a washer. My next question is- does the vertical have to be the same diameter of the stick? If the hole is 1/4, why not use 5/8 or so tubing for this?
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
02-15-2009, 02:40 PM
Mario,
On my stick (RV7A), the lower portion of the stick (below the pivot) is aileron loads only.
Bevan
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
