  #21
Old 02-13-2009, 01:37 PM
rvmills's Avatar
rvmills rvmills is offline
Bob, hard to tell from the photo, but it looks like the stick is double walled at the position you drilled.
In addition, the pivot point is pretty well reinforced by that gusset plate.
Looks pretty strong compared to the modeling Bill did.
How is the snow doing???
Thanks Mike, good thoughts. I can pull that snap bushing and confirm the double wall and or wall thickness too!
Snow is off and on. Cold though! Small window for flying yesterday! Woo hoo!
Originally Posted by Pmerems View Post
When pulling out of that steep dive just after you released that 500 lb bomb puts quite a load on the stick so we need to be careful In my opinion the aileron loading on the stick is much less, so why not put the hole on the side of the stick?????
Paul
Yes, but once that 500 pounder drops off, your GW will have dropped by 25-30% or more, so the pull shouldn't be that bad...unless you got target fixation and waited too long to pull out! (OK, OT, but fun).
One thought though...what you said about the lower force on the ailerons (or side stick pressure used) makes sense...but if your roll servo or aileron locked up, you might have to use a pretty good amount of force to break it loose. Maybe that's an unlikely scenario, and is different from "putting your feet on the panel and pulling", but perhaps the reinforcement of the hole on the side couldn't hurt either...if it's ultimate safety we're after. Not challenging your assumptions...I'm not an M.E.!
Originally Posted by vlittle View Post
Doctor, it hurts when I do this! So stop doing it! It's perfectly acceptable to run the cable externally to the stick secured in this fashion. Put it on the leading edge of the stick and you will barely notice it. If you don't want the C-clips, wrap the stick and cable with cloth tape (like you get at the bike shop).
Greatly simplifies installation as well. The grip, cable and connector can be wired externally then fitted to the stick later on.
Thanks Charlie!
Vern and Charlie, this makes sense too, but what about stick grips whose wires run straight down through the bottom of the stick insertion piece (like my CH/Tosten grips)? The wire(s) need to come out somewhere...one thought might be that if you bring them out at or near the top, then the arm to the hole is pretty short, and you probably won't be able to generate enough force to break the stick up there. Not sure if that is a good or bad idea from an engineering perspective, and don't want to start "hole wars"!
Running a wire down the back or front of the stick wouldn't bother me if I was re-doing this, and the handlebar tape would make a nice cover too. FWIW to consider, my boots actually come up to the bottom of the stick grip anyway, so such an external install might just be covered up anyway.
Just thoughts!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 02-13-2009, 01:44 PM
MNAv8or MNAv8or is offline
You could easily put a hold in the stick and do it in such a way as to not reduce the strenght at all.
Take the hole you have drilled in the 4130 control stick, take another piece of 4130 steel tubing the same diameter as the stick and fishmouth cut the small piece of tube. Use AC43-13 1B to see how it is done and for pictures. Now weld the piece over the hole that you have drilled to where the smaller piece is 90 degrees to the control stick with the fishmouth cut fitting over the hole you have cut in the control stick. Now file and sand down the 4130 tube piece to create a 1/8 lip or the desired height you want of the lip. This is somewhat along the lines of the washer idea except its the FAA way. And we all know that the FAA way is the ONLY way..
This is the same type of welding tech used to build airplanes so I think it would be ok. Just my two cents. If you really want to know if it will hold up, I'm sure someone would test it and see.
Old 02-13-2009, 08:41 PM
4kilo's Avatar
4kilo 4kilo is offline
Originally Posted by fl-mike View Post
I wonder if Pat has any holes drilled in his stick, and if so, how large are they and where are they located?
I was a little concerned about drilling a hole in the stick. I only had two wires to contend with, so my hole is only about 3/32" with a rubber grommet. Two 22 gage wires just barely fit through the grommet. The hole is about one inch above the pivot point and is on the side of the stick. There does not appear to be any deformation after my 'event.'
Pat
Pat Tuckey
RV-8
Superior IO-360, Hartzell blended airfoil, GRT dual screen EFIS
Flying 1400 hours
Formation Acro SAC Card
FFI flight lead
25XS (Waxahachie, TX)
Old 02-13-2009, 08:54 PM
Greg Arehart's Avatar
I ran my wires down the tube and out the bottom (carefully), so no hole at all. I only have a PTT pair and obviously a larger set of wires might not do so well. Anyone see a potential issue with just having the wires out the bottom?
greg
Greg Arehart
N 7965A
Old 02-13-2009, 10:54 PM
rgrigson rgrigson is offline
Default Another concept to strengthen tube
Hi all,
Another concept to strengthen tube. Buy some larger diameter 4130 tube from spruce, cut a 2" long piece, slide it down your control stick and drill a hole where you want the wires (telescoping tube).
For example, if I wanted to strengthen my 1" OD RV-8 front stick around the hole I drilled, I could but some of the following:
1 1/8 OD .058 Wall Part No: 03-07100 $3.70/ft
It has a 1.009 inch inside diameter. Slide a 2" piece down your tube, drill the hole and call it a day. You could weld it on, bond it on, or even have a couple of screws. Take a closer look at the RV-8 rear stick and you'll see what I mean.
Cheers
Robert Grigson
Old 02-13-2009, 11:41 PM
Jim P's Avatar
Jim P Jim P is offline
Since the -8 and side-by-side models have very different sticks, I'd be interested in seeing what the FEA looks like on the side-by-side sticks with the offset pivot points. Seems like the analysis may be applicable to the centerline models with the pivot through the stick.
Jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 02-14-2009, 07:18 AM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
Default Hole location - worst vs. best case
I my opinion the aileron loading on the stick is much less, so why not put the hole on the side of the stick?????
Bill's FEM analysis and Frank's testing are both very interesting approaches to this problem, but both are assuming a hole in the worst possible place. It seems like putting the hole anywhere other than right above the pivot would improve the situation
I'd be interested to see similar analyses with a hole a few inches higher and on the side.
Alan Carroll
RV-8 N12AC
Old 02-14-2009, 09:04 AM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Another interesting idea, except I don't find this in AC43-13. Do you have a page number?
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 02-14-2009, 11:32 AM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default I went out the bottom
I have the thick wire bundle for the infinity grip and I went out the bottom. It does rub on the belly skin but there is not much pressure on the wire, the bundle has a thick outer sheath and if I see wear I will use spiral wrap to reinforce it,
Old 02-14-2009, 11:42 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Default redundancy
I have my secondary & redundant control system all worked out...........
In case of joystick failure. I'll just leave the wireless passenger stick, firmly bolted in................no matter how fat the passenger is!
L.Adamson --- RV6A
