Old 02-11-2009, 04:51 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default No hole yoke
I bought a 4 inch no hole yoke for those tight places like the trailing edges to sqz rivets. My problem is the base of the yoke is thicker than the regular yoke that came with my p.sqzr, thus the pin (normal pin, not adjustable) is too short to make a full sqz. I looked on avery's site to see if they had a longer pin but did not see one. Anyone have a suggestion.? I do have an adjustable pin but I think I messed it some time ago using not enough gap width (that's another story). The reason I think that is because when I use the adj pin it always gets stuck in the mist of the sqz, so I gave up on it ever since that gap episode. as usual thanks all for the advice. My tail is almost done so my dumb questions should cease until about March when my wings arrive.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 02-11-2009, 04:58 PM
cln1owner's Avatar
cln1owner cln1owner is offline
You may have to round up some taller squeezer sets...
See this thread:
http://www.vansairforce.com/communit...ad.php?t=39617
I sometimes even use 1 or 2 washers as well for height adjustments... then use the adjustable pin to tune it in perfect.
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
"If you think you can do a thing, or think you can't do a thing, you're right." -- Henry Ford
Old 02-11-2009, 05:42 PM
smokenjoe50 smokenjoe50 is offline
You need a longer set holder 2-13/16
http://www.store-planetools.com/inde...ROD&ProdID=150
Old 02-11-2009, 05:55 PM
miyu1975's Avatar
tool ordered..thx
Ryan Allen, CFII
E-170/175
