Old 02-11-2009, 01:37 PM
wickedsprint wickedsprint is offline
Default Worth installing a VOR for VFR ops?
So to those that fly VFR a lot, how often are you using VORs as backup? I know when I rent I am usually in mostly familiar areas so I am content to use the GPS for direct to courses and not bother with the VOR. Is it worth the extra few grand to have working VOR for someone who will fly strictly VFR? Aren't they phasing it out anyhow? My mission will be fun flying mixed with some longer cross country flights..so I was almost thinking a second GPS with an aviation database might be more useful..ie a 250Xl with a 495..or something along those lines.
-Tony
Cheyenne WY/ Iraq
Private pilot...still in research stage for a -8
Old 02-11-2009, 01:47 PM
JDRhodes JDRhodes is offline
I wouldn't. Get a second GPS if you want a back-up. Or a map!
Jeff Rhodes - Taylorsville, GA
RV-9, 7 - going fast
BC-12D - going slow
jrhodes@v1salesmgt.com
Old 02-11-2009, 01:52 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default VFR & VOR....
If you truly will only fly VFR then spend the money on a good GPS instead. I flew my Long-EZ ALL OVER the US with only a Garmin 195! Never turned on a VOR except to see if it even still worked.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
sjhurlbut sjhurlbut is offline
Forget about the VOR for VFR nav. Get a good GPS. If you want to follow a VOR radial just dial in the VOR identifier and the required track on the GPS.
Steve
7A
Old 02-11-2009, 01:57 PM
Scott Hersha Scott Hersha is offline
I agree. You don't need a VOR if you're never going to fly IFR. It's costly, has an ugly antenna and not as useful as a GPS. If you want a back-up, get a second inexpensive hand-held GPS. You may want to plan for a possible VOR/ILS reciever while you are building, in case you change your mind and want to go IFR later. I did this by building a doubler in to the belly of my RV-8 back by the tail with a small hole where I would drill for the antenna. Then I ran a coax cable with a BNC on it to make installation easy. The other end of the cable terminates behind my panel in a coil - with ne end on it for now - to be connected if I so choose in the future.
Scott
frankh's Avatar
frankh frankh is offline
Default Amen
I never end up using VOR even for IFR flight..Note the FAA is propsing to dismantle the VOR network as IFR GPS's have their locations installed in them anyway.
I guess they will be virtual VOR's at that point.
Frank
Old 02-11-2009, 02:02 PM
gasman gasman is offline
You can fly VOR's with your gps. At least you can with a AIRMAP 600c.
Old 02-11-2009, 02:03 PM
So it seems there is no vote for a VOR install, however I agree prudent to consider the room for future expansion should I decide to go that route. I would probably go wingtip ant though as I hate adding drag if I can avoid it, after all these planes are made to boogy.
-Tony
Cheyenne WY/ Iraq
Old 02-11-2009, 02:30 PM
the_other_dougreeves the_other_dougreeves is offline
GPS. Only possible exception is somewhere that you need to follow a lot of VOR radials - SoCal basin, for example - and that's easier with a VOR than GPS - or if you want to be able to practice LOC and/or GPS approaches, but you said VFR.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 02-11-2009, 02:37 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Default Communication
I don't think it is a compelling reason, but there are still quite a few places where the only communication with Flight Service is through a VOR station.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
