Old 02-11-2009, 11:24 AM
John Clark's Avatar
John Clark John Clark is offline
Default North Las Vegas (KVGT) in the news again...
This just appeared on Aero-News:
Lawmakers Introduce Resolution To Ban Homebuilt Planes From VGT
Wed, 11 Feb '09
Says Experimental Planes 'Have Higher Accident Rates' Than Other Types
The sentiment among residents and lawmakers in Las Vegas, NV against homebuilt aircraft has reached the state assembly. Aero-News has learned State Senator Steven Horsford and Assemblywoman Marilyn Kirkpatrick introduced a joint resolution Monday than, if enacted, would ban all flights by homebuilt aircraft from North Las Vegas Airport (VGT).
According to documents received by Aero-News, Senate Joint Resolution 3 urges Congress "to authorize the Clark County Department of Aviation to ban flights of experimental homebuilt aircraft to and from the North Las Vegas Airport." The resolution asserts "experimental homebuilt aircraft have higher accident rates than other types of aircraft and accounted for more than 12 percent of airplane accidents nationwide in 2007," noting homebuilt planes "have been involved in more than 20 accidents in Clark County since 2003..." and "resulted in the deaths of several persons on the ground in 2008." As ANN reported, the latest outcry against experimental aircraft operating from VGT came following the August 22, 2008 downing of a Velocity 173RG (similar to type shown below), which claimed the lives of the pilot and two persons inside the North Las Vegas home the plane impacted. The accident spurred Clark County Aviation Director Randy Walker to call for all homebuilt planes to be banned from "busier" airports.
While the NTSB's probable cause report has yet to be issued, preliminary evidence indicates the accident flight was the first for the plane after the installation of a non-approved engine supercharger... taking the aircraft out of its originally certificated approval parameters.
With just 5.1 hours on the Velocity, it also appears the pilot was operating the aircraft over North Las Vegas without authority from an FAA inspector or Designated Airworthiness Examiner. The plane's logbook showed a notation authorizing operation for the first 25 hours only over sparsely populated areas, with an exception granted for the aircraft's home base of Show Low, AZ.
Here are the websites of the two responsible for this:
FMI: www.stevenhorsford.com, www.marilynkirkpatrick.com
John Clark
RV8 N18U "Sunshine"
KSBA
Old 02-11-2009, 11:40 AM
flytoboat's Avatar
flytoboat flytoboat is offline
Default Air Force One
Isn't Air Force One an Experimental? Are they going to tell the President he can't fly into their airports?
Don
VAF #1100, EAA864
-6A bought flying
Old 02-11-2009, 11:52 AM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
That statement is false. If the resolution is approved, it just means that the state legislature in Nevada urges the US Congress to enact a law allowing them to ban "homebuilt" aircraft. The resolution itself doesn't ban anything.
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 02-11-2009, 12:31 PM
John Clark's Avatar
Default Potential
True, the Aero-News writer got a little ahead of themselves but that doesn't change the big picture. Two state lawmakers have re-opened an issue that the "alphabet groups" thought they had under control.
John Clark
RV8 N18U "Sunshine"
KSBA
Old 02-11-2009, 01:01 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
You also have to consider that if the flight in question was done with callous disregard for flight safety...as some pilots do...then his selfish actions just provided the fodder for what we see now.
Old 02-11-2009, 01:46 PM
Steve Brown Steve Brown is offline
Default The point is..........................
With just 5.1 hours on the Velocity, it also appears the pilot was operating the aircraft over North Las Vegas without authority from an FAA inspector or Designated Airworthiness Examiner. The plane's logbook showed a notation authorizing operation for the first 25 hours only over sparsely populated areas, with an exception granted for the aircraft's home base of Show Low, AZ.............
John Clark
RV8 N18U "Sunshine"
KSBA
That there is already a law that makes this illegal. In typical moronic legislative form, they are trying to make something which is already illegal, more illegal, while simultaneously throwing out the baby with the bathwater.
Steve Brown
N598SD - RV9A second owner
O-320, 9:1 pistons, Catto 3 blade
KRHV - Reid Hillview airport, San Jose, CA
Old 02-18-2009, 06:07 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Default EAA calls for a member 'stand-down'
Just saw this on the EAA website, and it looks like there is positive progress happening Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
