02-11-2009, 06:35 AM
Recommendations for making a 2" dia. hole in the firewall
After 8 years of flying, I've decided it's time to put heat in my -4. During the building phase, I found it very difficult to put even moderately sized holes in the firewall. What have other builders found to work to make nominal 2" diameter holes for heater plumbing?
Thanks!
02-11-2009, 06:44 AM
Thanks!
I was going to say a double barrel 12 ga might work...I used a metal cutting 2" hole cutter from Home Depot. Don't recall the brand but they are white and cost more than the red ones hanging next to them. It is a good idea to have someone hold a piece of 2x4 on the other side so as not to flex the firewall too much.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
02-11-2009, 06:54 AM
Did the same
I did the same and it worked well. A word of caution if using something like a Greenlee slug buster. All the dies actually cut a bigger hole than what they are labelled for. A 2" cutter actually leaves a 23/8" hole. The home depot hole cutter did the job very nicely in about 5 seconds.
02-11-2009, 06:57 AM
I just used the biggest unibit I had, then enlarged the hole from 7/8's to 2 in. with a carbide burr in a die grinder. Finding someone to back up the firewall with the 2x4 has never been convenient for me, but may be less messy.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
02-11-2009, 08:22 AM
if you can get a hold of a hole punch for the panel 2 1/4, makes a real nice hole, easy to do. That's how I did my hole for the heat.
02-11-2009, 09:11 AM
The heat box on my 9 is attached with a couple AN3 bolts on either side of the large 2" hole. I drilled the holes for them before drilling the larger 2" hole and then used a couple large wood screws and washers to fasten a piece of 2 by 4 behind the FW for backing. I then drilled the 2" hole with a typical metal hole saw, go very slow to avoid heat build up and use some type of lube.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
02-11-2009, 03:44 PM
Same here - looks good and the flange on the valve is more than big enough to cover the extra 1/8" all around.
Jim Sharkey
02-11-2009, 05:51 PM
Jim Sharkey
Use it on the baffles also for the cold air.
02-11-2009, 05:52 PM
One more use for it was on the battery box.
