Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
  #11
Old 11-03-2005, 08:06 PM
praterdj praterdj is offline
Default 396 all the way
I currently fly a 182 equipped with a Garmin 430. I own a 196 as well that I use in various other aircraft. I actually prefer the 196 over the 430 both for display and the extremely easy to use menus on the 196.
When my 8 is complete it will have the new 396 up front and I plan on mounting the 196 behind the pilot seat. This will be available for a back up if needed and provide the rear passenger with a display. They can also use the page that displays the flight instruments.
Just my plan.
Donald Prater
RV-8 Empennage
N284DP (Reserved)
Old 11-11-2005, 04:53 PM
flydoc flydoc is offline
Default Wx & Street Mapping
This has maybe been brought up before, but does anyone know if the Wx function works while in Street Mode?
Mark
Old 11-11-2005, 06:31 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Mark
You can download the complete manual from the Garmin website. But quickly looking through it, I found a section for selecting weather tabs for aviation, surface, and marine; with options of displaying desired weather options over the map. I'm just a 296 owner that wants a 396!
Old 11-11-2005, 10:26 PM
Tandem46's Avatar
Tandem46 Tandem46 is offline
Mark,
I was using my 396 the other day in car mode, and when I zoomed out it did show the radar and clouds. I don't remember seeing anything else, but wasn't looking either.
Tobin
RV-7 Flying since 2004
1,100 hrs+
Old 11-29-2005, 11:36 AM
N395V's Avatar
N395V N395V is offline
Default Removing the magnets from the 396WXWRKS RCVR
No doubt by now some of you have noted your 396 weather antenna has magnets in its base and that they adversely affect your magnetic compass.
Garmin tech reps have been less than friendly about taking them out.
The following procedure for their removal was developed by a CPA member. I have photos I can e mail for anyone interested.
GXM30 magnet removal instructions
Notice: This is NOT an approved procedure! Disassembling this antenna/receiver will void any warranties and you could damage the antenna/receiver. Proceed at your own peril!!!
Flip the antenna over and locate the four small screws.
Remove the four screws circled above and remove the bottom slightly to gain access to the connector.
Gently (carefully) unplug the connector. There is no latch or tab holding the connector. The connector is also keyed so it can only be reconnected one way. Once unplugged, set the cover aside.
Carefully peel the copper foil that the serial number label is attached to. You will want to reaffix this during reassembly so put it someplace where it won?t get damaged.
Loosen the four screws . They don?t need to be removed.
Once loosened, pull them up
Lift up on the top half of the unit.
There is a small connector that connects the top half to the bottom half that will offer some resistance when removing the top.
On the left is the connector that connects to the top half. On the right is the connector to the external cable.
Remove the three screws and lift off the circuit board.
Paydirt! The two magnets (circled) that cause the problems with your magnetic compass are now ready to be removed. There are also spots for two additional magnets!?!? (I guess if you wanted to attach on the outside of an F15)
They are held in place with a small amount of glue. Some people have been able to get them free by inserting a very small screwdriver between the magnet and the box around it and prying them out. All I accomplished was bending a small screwdriver. What worked for me was to place the blade of a small screwdriver between the magnet and the box and hit it (lightly) with a small hammer. I did this around the perimeter of the magnet until it was loose. On one magnet, I broke it loose on the first tap. The second magnet didn?t come loose until the third side. Then I removed it by working it out with another very small screwdriver.
Reverse the disassembly steps (don?t forget to affix the serial # label) and that?s it!
Old 12-11-2005, 03:33 PM
Oldgeezer Oldgeezer is offline
Default Garmin 396 and TruTrac autopilot
Question: will the Garmin 396 drive a TruTrac autopilot and if so has anyone using it experienced any problems?
Old 12-11-2005, 04:33 PM
petehowell's Avatar
Default Trutrak and SL40
Hello,
I want to drive a Trutrak and an SL40 comm with the 396, i have the wiring harness and there are 2 wires labled data out, can you run one to each or does one need to be split?
Garmin 396/296 output
Red DC Input
Blue Port 1 Out
White Alarm
Orange Voice (-)
Violet Port 2 Out
Black GND
Yellow Port 1 in
Brown voice(+)
Green Port 2 In
TIA
Pete
Old 12-11-2005, 04:44 PM
dan's Avatar
dan dan is offline
Default 396 has only one serial port
The Garmin GPSMAP 396 has only one serial port, but uses the same plug & harness as other Garmin handhelds, which do have more than one port. Just use the data port 1 wires.
Been using my 396 to send serial data out to my SL30, TruTrak Pictorial Pilot, and the AF-2500 now has NMEA processing to support knots per gallon, miles per gallon, gal remaining at XXX, gal required to XXX.
Great stuff!
)_( Dan
RV-7 N714D (720 hours)
http://www.rvproject.com
Old 12-11-2005, 05:49 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Question Ignorant Question: GPS ->SL30
OK, I admit it, I'm stumped. What does sending GPS data to the SL30 accomplish?
h
Old 12-11-2005, 06:22 PM
L.Adamson's Avatar
h
Since I was curious, I found the answer.
DME information (estimated time en route, ground speed, and distance) provided by either a remote DME box or GPS receiver can also be displayed on the SL30.
