Old 02-09-2009, 05:19 PM
jscottpilot jscottpilot is offline
Default Cost for O-360 cylinders
I have just bought a O-360 core for rebuild and cant find prices for new cylinders for this engine on the internet. Does anyone know the approximate price for a new cylinder?
Old 02-09-2009, 05:37 PM
RVadmirer RVadmirer is offline
Look to the left on this page at A.E.R.O.
They have what you are looking for. There are other sources but these folks are pretty competitive and I would buy from them when the time comes.
Old 02-09-2009, 06:18 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
My recollection from almost two years ago is circa $1000 each new.
Old 02-10-2009, 12:52 AM
asav8tor asav8tor is offline
Thumbs up
Of all the things that go up, up, up. Cylinder kits have gone down, in absolute and adjusted for inflation dollars. A good deal.
Old 02-10-2009, 06:33 AM
az_gila's Avatar
az_gila az_gila is offline
Smile ....but recently they seem to be...
going up....
ECI from AERO - $1042 for Nickel.... IIRC, seems to be up a bit in the last year - $993 in July 2007 according to the internet archives....
http://www.aeroinstock.com/products/...cat/index.html
I guess Superior leaving the market did not help....
Genuine Lycoming ones seem to be $1028 from Mattituck
http://tcmlink.com/mattituck/cylinders.cfm
...again a change, the ECI ones used to be cheaper...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-10-2009, 11:48 AM
RV6_flyer's Avatar
Originally Posted by az_gila View Post
going up....
If you live in a dry environment, you could use the NEW ECI steel cylinders at $890.59 from AERO. http://www.aeroinstock.com/products/...cat/index.html
I HAD Superior steel cylinders for over 2,100 hours. The bore was still standard including the choke. Lycoming says the through hardended steel cylinders are the softest on the market. Mine showed no wear after 10-years and 2,100 hours.
I am presenlty running the NEW ECI Steel cylinders with less than 50 hours since installing them. Broke in a few hours. Used about 1/4 quart of oil in 10-hours. Now down about 1/3 quart after 13 hours.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-10-2009, 05:39 PM
az_gila's Avatar
Thumbs up Thanks Gary....
...that's a really good data point for those of us in dry AZ...
And the 15+% savings is quite significant.
Gil Alexander
