Old 02-09-2009, 03:43 PM
Lou's Avatar
Lou Lou is offline
Default Riveting ribs (tight spot) next to trailing edge.
I just finished with the practice control surface kit. The last two rivets (most notably the last) on the rib next to the trailing edge are in a tight spot. I suspect most of you are probably thinking to your selves "ya, you haven't seen anything yet there newbie". I have a Cleaveland main squeeze and the 3" yoke which is just too big for this tight area. I was able to use the gun and a tight fit dimpling fixture from Cleaveland turned around and anchored, but it did not have the mass to do the job properly. Do I need to think about the 4" thin nose no hole yoke or is there a better way. I am suspecting that most of the bucking bars will be too big (only have the 2.2lb footed right now).
Old 02-09-2009, 03:47 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
I did mine on the back rivet plate with a splitting wedge and a hammer. Someone has a good writeup on this... I'll see if I can find it.
Edit: Here it is! I need to organize my bookmarks better...
http://www.experimentalaero.com/Builders%20Tips.htm
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 02-09-2009, 04:30 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Lou View Post
.........The last two rivets (most notably the last) on the rib next to the trailing edge are in a tight spot........
There are various ways to approach the problem. One example is to temporarily plug the upper hole on a suitable yoke. In this example, I inserted a SS screw, its slots sanded off into the yoke thus providing adequate clearance to set the last two rivets in this elevator skin. Don't be confused by the reflection. Careful observation will reveal the shop heads have been set per spec using the yoke shown.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 02-09-2009, 05:11 PM
Lou's Avatar
Lou Lou is offline
Default You folks are the greatest!
Andy, Rick, thanks, two great ideas back to back. I need to think out of the box abit more.
Old 02-10-2009, 07:19 AM
What about just adding a no-hole yoke to that squeezer?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 02-10-2009, 07:26 AM
N208ET N208ET is offline
Default no-hole yoke very useful
I just ordered a no hole yoke from cleaveland for my main squeeze, and I am on the finishing kit. They are very useful. If you have the money, it will pay for itself by the time you are done.
Randy
8A
FAB is a real pain
Old 02-10-2009, 04:42 PM
Lou's Avatar
Lou Lou is offline
Default Thin nose no hole
Looks like that might be the ticket. I was not sure how thin the nose piece of the "thin nose no hole yoke (4")" section actually was. Between this and Andy and Rick's suggestion I should be in good shape. I see that a few of the A/C tool suppliers are having sales on the squeezer yokes. Probably a good time to get one.
Thanks everyone, I should be ordering the tail kit as soon as Uncle Sam figures out his fair share for tax season.
