Originally Posted by andrew phillips
I got a piece of aluminum tube with an inner diameter that would allow my step drill shaft to fit snugly inside. I drilled and tapped a hole for a set screw to lock it in place. This extension for my drill bit allowed me to drill all the holes from the root end of the wind without any problems.
We did something similar. We took a step bit and ground all the larger steps down to the correct size we needed for the holes. We then brazed that to a piece of 4130 tubing that would chuck into our drill. The 4130 is stiff so very little flexing occurs. It worked out very well.
