Old 02-09-2009, 01:00 PM
dacrunk dacrunk is offline
Default Aluminum spinner for c/s prop
Does anyone have a source other than Hartzell for the 835-54P aluminum spinner?
Also, has anyone used this unit on a RV-8?
I had an aluminum spinner for my last -8, but I can't find the 10 year old receipt. I purchased it from another source at a substantial savings over Hartzell's price.
Jim Crunkleton
Old 02-09-2009, 09:03 PM
mcencula mcencula is offline
Default eBay
I see two on eBay. $550 Buy it now price.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
Old 02-09-2009, 09:37 PM
Thanks Mike.
I'll order it tomorrow.
Jim Crunkleton
Old 02-10-2009, 11:47 AM
Default Still trying to find a Hartzell aluminum spinner
Mike,
I guess I'm back to square one as the Hartzell 835-54P will not fit the RV-8, in spite of what Hartzell says.
That spinner mounts to the ring gear and the -8 needs a hub mounted spinner.
Oh well, back to the aerodrome to see if I can spot one that will fit.
Jim Crunkleton
Old 02-10-2009, 12:49 PM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Default Spinner
I have one.
It came off a mooney with a porsche engine. there is not a scratch or dent in it, and it mounts to the hub. I was thinking of using it on my -4 when I up grade the prop to C/S
But I would sell it
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
Old 02-10-2009, 01:05 PM
DanH's Avatar
DanH DanH is offline
<<That spinner mounts to the ring gear and the -8 needs a hub mounted spinner.>>
You can do it, just need to mod the cowl. Been there, done that.
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-10-2009, 01:47 PM
chaskuss chaskuss is offline
Default Cowl Mod
OK Dan,
Spill the beans. How involved is the cowl mod? I assume you have to reshape the area around the crankshaft hole?
Charlie Kuss
Old 02-10-2009, 03:26 PM
DanH's Avatar
Charlie,
The one I did was actually for a McCauley, but I think the Hartzell spinner mounting is pretty much the same....big 'ole dishpan between the ring gear carrier and the spinner. You just need a larger hole for the dishpan. Don't want to lose stiffness in the cowl nose, so extra plies of glass are required.
My buddy wanted a 14" spinner and had already butchered the cowl nose, so I built a whole new nose, inlet-to-inlet.
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-10-2009, 03:45 PM
Dan,
The ring gear carrier hole pattern is 11" out to out which would require removing LOTS of the cowl. I guess you could stiffen it with kevlar rope, but that's not for me. (How does anyone build a glass airplane!)
My hat's off to you for your buddy's rebuild.
I know Hartzell makes a spinner that will fit the -8 as I had one....I just don't remember the model number.
Jim Crunkleton
Old 02-10-2009, 06:20 PM
Larco's Avatar
Larco Larco is offline
Some people have found a spinner here. Like Vans but metal, they look good. I would call them directly to see if they still make them. Larry
http://www.acsproductsaz.com/
