Old 02-09-2009, 07:48 AM
Allan Stern Allan Stern is offline
Default Ground Adjustable Rudder Pedals
Have started to dry fit my ground adjustable pedals and noticed that the right angle with bolts attached is awful close to the aluminum baggage bulk head. So with it installed, you would not be able to remove the bolts and adjust the pedals unless you take the skin out.
So how have you folks handled this? Drill some holes in that skin in relation to bolt holes in the floor angle so you can remove the bolts and adjust the pedals if needed?
Old 02-09-2009, 08:10 AM
N208ET N208ET is offline
Default I put my bolts threads facing outboard
And I had enough room. You could put the bolts the other way, but like you said, on the starboard side you would have to take the baggage compartment floor and wall out. This isn't to big of a deal for my plane, and you wouldn't have to dive under the instument panel to adjust anything with the good access.
Randy
8A Finishing, FWF
Old 02-17-2009, 03:34 PM
kens_cockpit's Avatar
kens_cockpit kens_cockpit is offline
Default Same issue discussed in this thread
See this thread.
http://www.vansairforce.com/communit...e+rudder+pedal
Ken Stanton
RV8 QB
Wing attach
Building a plane again after building family
We inhabit a mystery. We should not pretend to know too much.
-Eugene Peterson
Old 02-20-2009, 11:04 AM
gmshelley gmshelley is offline
Default Keep it simple
Allen, I just placed bolts with washers and nuts in the other holes that might be used.
Gary Shelley
RV8, SARL Race 81
Hutto, Texas
