Old 02-08-2009, 11:07 PM
sjjonesnz sjjonesnz is offline
Default High Density D-sub Crimp Tool
Man, this project is all little things slowing us down!! I've got ~15 pins that I need to add to the d-sub connectors going into the back of my PMA8000B and GNS430W, and I can't put the panel in until they're done.
I have the 4-way indent crimper from Stein for the normal d-sub connectors, do I really need to get the (very expensive) AFM8 type as well?
What cheaper/easier alternatives are there?
Cheers
Steve
Auckland, New Zealand
Flying RV-7QB/ZK-NVS/Aerosport 0320/Dual AF3500s/PMA8000B/GNS430W/SL30/GTX327/TT ADIP II
Old 02-09-2009, 10:27 AM
breister breister is offline
It might depend on the size of wire you are using. I got a single tool for crimping D-Sub pins, not sure what model it is though. It crimps high and normal density D-Sub pins just fine - and as a bonus I was able to use it to successfully crimp the tip covers on several BNC fittings. It required a little jiggling after crimping to remove the pin from the crimper - was a bit worried it might be stuck forever!
I'm fairly certain it was this one, which is found on this page.
Edit / Note: if you are using very fine gage wire in the pins, I'm not certain it would crimp the high density ones "tight enough." I don't remember the exact gage wire I used, but the strands completely filled the hole (getting old, had to use magnifying glasses to insure all the strands actually went in the hole).
Old 02-09-2009, 10:40 AM
MCA's Avatar
MCA MCA is offline
You want to use a Daniels AFM8 crimper with a K41 or K42 positioner. You can get it used on ebay or new from the usual avionics places.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 02-09-2009, 12:14 PM
So, the Daniels crimper plus two positioners = $455. The other one is $31.
I don't know - I pulled pretty hard on my high density pins and they wouldn't slip after crimping with the $31 tool. They also inserted (and, when I cleverly put them in the wrong holes, easily extracted) without issue.
Caveat emptor.
Old 02-09-2009, 12:22 PM
WiseGuy WiseGuy is offline
Default Crimper
Have also used the $31 crimper on the small barrel pins and havn't been able to pull the wire out in a pull test. FWIW that is what I use....
Old 02-09-2009, 12:32 PM
Brantel's Avatar
Brantel Brantel is offline
I would say if they pass the pull test and your not in mass production mode, they will be fine with the cheap tool.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 02-09-2009, 12:41 PM
Pilottonny Pilottonny is offline
Default Fold back and double up, if necessary.
If the wire is to small, you can always fold it back and double up, even partially, if necessary, to fill the pin some more. After a positive pull test I would not worry about it. (or would that be a negative pull test??, i.e. it was not possible to pull the wire out!), Anyway, you know what I mean.
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 02-09-2009, 12:42 PM
PJSeipel PJSeipel is offline
I used the 4-way $31 model as well. If you were doing an entire panel with lots of glass and hundreds of pins, then the Daniels tool might be worth it. For a handfull of pins the $31 tool did me just fine.
PJ Seipel
RV-10 #40032
Old 02-09-2009, 10:29 PM
Fantastic, thx guys. 'tis nice not having to spend more money for a change :-)
Cheers
Steve
Old 02-10-2009, 05:15 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default 31 dollar crimper
Just a note,
If you are using the Deutz connectors anywhere on your plane, (Very good waterproof shell and pin) The little crimper will crimp those buggers perfectly with just a slight depth adjustment. I use these a lot at my day job as an auto mechanic. The official tool from deutz costs a weeks salary!! I've crimped a zillion of them with that little crimper. Tougher than it looks!!!!
Lancair guys use a lot of them, see www.aerocraftparts.com for a selection of shells and pins
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
